Topic: compass directions and discrepencies (Read 3047 times) previous topic - next topic
dedly13
i am writing some code for handleing a compass sensor to get the value that the robot is off course by. i can tak a value from the sensor from 0 - 359. the problem comes when you are currently heading at 350 degrees or so and the course you should be on is at say 10. the numbers cant be taken away and im not sure how to universaly say "if you are off to the right, turn left a bit" and vice versa. not sure on this one. all ideas apreciated
robtillaart
#1
Feb 13, 2011, 10:37 pm Last Edit: Feb 14, 2011, 11:44 am by robtillaart Reason: 1
something like this?  (not tested)
doSmartTurn(int curDirection, int newDirection)
 delta = newDirection - curDirection;
 if (0 == delta) return;  // no need to turn;   better use: if (0 == (delta % 360))
 if (delta > 180) turnRight(360 - delta);
 else if (delta > 0) turnLeft(delta);
 esle if (delta > -180) turnRight(-delta);
 else turnLeft(360+delta);
Rob Tillaart
dedly13
I'm not entirely sure that solves the problem but thanks for reply
robtillaart
The idea behind the code is to never turn more than 180 degrees, otherwise it is faster to turn the other way : TurnRight(300) ==TurnLeft(60)
A piece of code like this should be somewhere in your sketch
  wantedDir = 10;                           // or determined some other way e.g. XBEE.Read()
  currentDir = compass.ReadDirection();     // or something like that
  doSmartTurn(currentDir, wantedDir);
Of course it can be in another separate function instead of in loop()
I looked at the doSmartTurn() => fixed a bug as directions could be >> 360 and a typo
// version 0.2
doSmartTurn(unsigned int curDirection, unsigned int newDirection)
  // force directions between 0..359
  curDirection %= 360;
  newDirection %= 360;
  int delta = newDirection - curDirection;
  if (0 == delta) return;         // no need to turn;      // better?  if (abs(delta) <= threshold) return; // don't do small angles.
  else if (delta > -180) turnRight(-delta);
Rob Tillaart
dedly13
u....are....a....genius! thankyou so much!!!
robtillaart
Too much honor, just took pencil and paper and played the robot to understand how the behaviour should be and what information was available at any moment. .. Give it a try next time (paper is patient :)
Rob Tillaart
