Topic: LCD  (Read 4812 times) previous topic - next topic
sinou
I connect the lcd with arduino mega : RS:A8    RW :A9  EN: A10  D4: A12   D5: A13    D6: A14     D7: A15
And I did this code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(62,63,64,66,67,68,69);
   lcd.begin(16, 2);
   lcd.print("Salut les Zer0s!");
BUT I have an error : redifinition of 'liquidcrystal lcd'
please some help
pert
When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
sinou
<Arduino : 1.8.5 (Windows 10), Carte : "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
E:\modele_pour_demarrer\modele_pour_demarrer.ino:26:18: fatal error: lino.h: No such file or directory
 #include "lino.h"
compilation terminated.
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Mega or Mega 2560
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
sinou
SORRY this is the message error  I receive :Arduino : 1.8.5 (Windows 10), Carte : "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
c:\program files (x86)\arduino\hardware\tools\avr\bin\../lib/gcc/avr/4.9.2/../../../../avr/bin/ar.exe: unable to rename 'core\core.a'; reason: File exists
Plusieurs bibliothèque trouvées pour "LiquidCrystal.h"
Utilisé : C:\Users\harisse\Documents\Arduino\libraries\LiquidCrystal
Non utilisé : C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
exit status 1
pert
This type of error can be caused by your antivirus software. Try TEMPORARILY disabling your antivirus for a single compilation to see if that makes the problem go away. If so, you will need to  whitelist the offending file/folder/process in the antivirus software.
GolamMostafa
Quote
The constructor format is:
LiquidCrystal lcd(RS, EN, D4, D5, D6, D7);
==> LiquidCrystal lcd(A8, A10, A12, A13, A14, A15);
Quote
The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
