Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Watchdog ISR in assembly language  (Read 3954 times)
Offline Offline
Sr. Member
View Profile
Can't you use the assembler .include directive? This works for me in Linux (I don't know about Windows).
Code:
asm (".include \"/full/path/to/sketch/asm.h\" \n");
extern "C" int func();
  Serial.println(func());
asm.h:
Code:
.section .text
.equ elo, 105
.equ ehi, 122
.global func
func:
  ldi r24,elo
  ldi r25,ehi
  ret
I use a .h file so the IDE doesn't complain, it's a bit of a hack. You seem to have to use an absolute path to .include, and you have to remember to save it in the IDE each time you change it before compiling.
« Last Edit: February 14, 2011, 08:24:00 pm by stimmer » Logged
nr Bundaberg, Australia
Online Online
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
asm("#define   SREG   0x3f\n");
asm("    in       r16,SREG\n");  // fails with "Error: constant value required"
asm("    in       r16,0x3f\n");  // works
@CB
I tried with and without \n, no difference. I often wondered about the \n in these assembler examples, it's the sort of thing you do when generating HTML code that has to be read by a human but you wouldn't expect it to be required here.
@Rob
I did the same with the small exception that I don't have python installed  smiley, I'll go and get it.
@stimmer
That approach produced 964
at com.oroinc.text.regex.Perl5Matcher._match(Perl5Matcher.java)
errors.
However I noticed your .equ syntax is different
asm(".equ SREG,0x3f\n");
asm("    in       r16,SREG\n");  // this works
but
asm(".equ r_temp1,r16\n");
asm("    push    r_temp\n"); // this doesn't work,  Error: register name or number from 0 to 31 required
asm("    in    r_temp,SREG\n"); // same error
Is this the ASM equivelant of "lvalue required"?
Anyway that's where I left it at 2AM last night. I'm back on deck now so will continue with this.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Sr. Member
View Profile
I don't know if you can properly use .equ or = to rename registers.
But it just happens to work under certain circumstances. In particular, don't make the first letter of the symbol 'r' and omit the 'r' from the register. ie:
.equ q_temp1,16
which is the same as
q_temp1 = 16
should 'work', at least for now.
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
I'll have to check the mechanics of having assembler included in your sketch when I'm at home with the source code.
I thought you could add a .S tab to your sketch just the way you can add .h, .c, or .cpp modules.  It may have to be capitalized...
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
View Profile
Huh.  It looks like the "Compiler" part of the IDE understands .S files, but the editor refuses to add such files to the sketch, or pass them to the compiler.  Hmmph.
Logged
Online Online
Tesla Member
View Profile
WWW
Fair dinkum this IDE is a crock.
Sketch>Add file... does nothing if it doesn't like the file type, at least have an error message.
It seems to add a .S file but doesn't show it in a tab
I don't normally use the IDE but I want what I'm doing to be available to the general Arduino crowd and most people do I think.
Anyway it's working in a fashion. Some mods to the py script (I've never used Python before, I gather the indenting actually defines the code blocks?)
Code:
import sys, os
def asm2include(infile, outfile):
    os.remove (outfile)
    line = ""
    with open(infile, 'r') as IN:
        for line in IN:
            line = line.strip(' ')
            if (line != ""):
                line = line.replace('  ',' ')
                line = line.replace('SREG','0x3f')
                line = line.replace('command','r18')
                line = line.replace('temp1','r16')
                line = line.replace('temp2','r17')
                line = line.replace('addlo','r19')
                line = line.replace('addhi','r20')
                line = line.replace('ZH','r31')
                line = line.replace('ZL','r30')
                line = line.replace('PORTB','5')
                line = line.replace('PINB','3')
                OUT = open(outfile, "a")
                if (line.rfind("//") == -1):
                    OUT.write("asm(\"")
                    OUT.write(line[:-1])
                    OUT.write("\");\n")
                OUT.close()
            print '.',
MAIN APPLICATION
print "ASM2include 0.1"
asm2include(sys.argv[1], sys.argv[2])
print "Done"
It deletes the output file and makes a few substitutions, no sanity test for the file delete so a bit dangerous at present.
.equ works on an "rvalue" but not an "lvalue", hense the py script replacements.
.equ   PIN_MOSI,3 // this works so don't bother with the replace
#define addhi   r20 // .equ addhi,r20 doesn't work, so leave this here just for reference
Leave all comments out, not point having them in the .S version
Then in the sketch
Code:
ISR (WDT_vect, ISR_NAKED) {
#include "d:\work\atmon\atmon\atmon_isr.s"
So it works but is pretty fugly.
The next step is to get both a C and ASM version working and see if there's much point in the first place  smiley
______
Rob
« Last Edit: February 15, 2011, 01:01:53 am by Graynomad » Logged
Online Online
Tesla Member
View Profile
WWW
Some improvements
.equ command,16
clr   command
works, (note no "r16", just "16")
so the py script is almost back to original
Code:
import sys, os
    os.remove (outfile)
    line = ""
        for line in IN:
            if (line != ""):
                    OUT.write("asm(\"")
                    OUT.write("\");\n")
                OUT.close()
            print '.',
MAIN APPLICATION
print "Done"
______
Rob
Logged
Online Online
Tesla Member
View Profile
WWW
I know you guys have been losing sleep over whether or not this is all worth it when an ISR written in C can be written in about 2 minutes. So I did a bit of testing.
The ISP function is basically to shift 3 bytes in, do a tiny amount of processing, then shift 1 byte out, all using what is essentially bit banged SPI.
Program size (including Arduino overhead)
ASM 858bytes
C (using digitalWrite()s) 1210 bytes
So there's a large difference mostly because of the digitalWrite library being pulled it, however in any normal program would have that anyway so the above comparison is not really fair. So in setup I added a single digitalWrite to pull in the library
ASM + 1 digitalWrite 1038 bytes.
The ISR code size is
ASM 212bytes
C 388 bytes
So with a normal program we're 176 bytes better off with ASM.
That's not a deal breaker, but have a look at the timing. Using a logic analyser (pics attached, pulse train at the top is normal program flow) I measured the interruption to main program flow.
ASM 37uS
C 400uS
That's a significant improvement, the ASM version is 10x faster. Also the ASM version could be even faster but I've had to add delays to allow the device (another Arduino) to catch up).
There is a third option of course, C with direct port manipulation which would presumably be somewhere between the two, I may write this to test it as well.
______
Rob
« Last Edit: February 15, 2011, 11:15:29 am by Graynomad » Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Quote
Imho these kinds of insights are worth it. They might cost a lot of time to build up but will save time in the end.
The speedup is so significant that one could think of rewiting digitalWrite (and other core functions) in asm(" ").
Keep us informed of the progress.
BTW what logic analyzer do you use? there is still one my wishlist smiley-wink
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
SF Bay Area (USA)
Offline Offline
Faraday Member
View Profile
Quote
C is not the problem.  There has been extensive discussion on speeding up digitalWrite and friends; search the forum for "digitalwritefast"...
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
@westfw
If C is not part of the problem, .... is it part of the solution then? or ... smiley
Know about the discussion about digitalwritefast, seen it passing by several times, thanks anyway  - Many (not all) performance problems can be solved by another design or algorithm, for the rest one can only buy more hardware or lower the requirements, and even that is not allways sufficient smiley
Logged
Rob Tillaart
Online Online
Tesla Member
View Profile
WWW
I said before
Quote
Well I've done another test and I was wrong, C with direct port manipulation is BETTER than assembler. I've always known C was good but I didn't expect this I have to say.
ASM with delays removed 28uS
C with direct mainipulation 26uS
Code size including Arduino overhead
ASM 858 bytes
C 778 bytes
Code size with neither routine 658 bytes
so the size of each ISR
ASM 200
C 120
Frankly I don't undertand the massive difference in code size, maybe my numbers are out a bit but either way this is very interesting.
As an ex ASM writer I think this is probably the end of my assembly writing days  smiley-eek
But what do I mean by "C with direct port manipulation"? An example of a byte shift in is as follows
Code:
  for (i = 0; i < 8; i++) {
    asm ("sbi 5,5");  // clock high
    cmd |= (PINB >> ASM_PIN_MOSI) & 1; // bit into LSB of byte
    cmd <<= 1;    // move bits up
    asm ("cbi 5,5"); // clock low
So you could argue that it's really half assembly anyway and as written it's not directly portable between different CPUs, nothing a few #defines or conditional code blocks can't handle.
But I think the point is that it's all written within the C/C++/Arduino environment and I think that's a big plus. It's also a 100 times more readable than the 150 lines of assembly language.
Quote
Rob, take it off your wish list and put it on your desk, I can't even imagine how people debug code that deals with IO without one. I reckon if everybody had an LA this forum would be half the size as there would never be a "I'm sending X and receiving Y" thread again  smiley
Anyway to answer you question, I use the Salaea Logic, I can't recomend it highly enough. At $170 it's a no brainer to me. In the "old" days with external peripherals you needed to spend $1000s on a 32-channel 100MHz job, but these days all the hard stuff is inside the chip and we're mostly looking at serial comms of one type or another so these new USB LAs are just the ticket for 99% of work IMO.
I also find it usefull for non-IO code, for example to see how often a function is called I pulse a pin and look at it with the LA. Or to see how many times I go through a loop I do the same.
______
Rob
« Last Edit: February 15, 2011, 11:47:15 pm by Graynomad » Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
View Profile
Code:
The current compiler is pretty good at turning C code like "PORTB |= (1<<PB5);" into a single sbi instruction when it is possible.
You did get rid of ISR_NAKED in your C implementation, right?
Logged
Online Online
Tesla Member
View Profile
WWW
Quote
He he, yep, after wondering for a while why the code kept restarting smiley
_____
Rob
Logged
Online Online
Tesla Member
View Profile
WWW
Hold the bus, C isn't quite as good as I thought, I was bitten in the bum by the optomiser.
I changed the code as westfw suggested, here's the three bytes being received.
Code:
    PORTB |= (1<<PB5);
    cmd |= (PINB >> PB4) & 1;  // I commented this line
    cmd <<= 1;
    PORTB &= ~(1<<PB5);
    PORTB |= (1<<PB5);
    addr_lo |= (PINB >> PB4) & 1;
    addr_lo <<= 1;
    PORTB &= ~(1<<PB5);
    PORTB |= (1<<PB5);
    addr_hi |= (PINB >> PB4) & 1;
    addr_hi <<= 1;
    PORTB &= ~(1<<PB5);
This runs like a cut snake at 27uS for the ISR.
For reasons that I can't remember I commented out the PINB line for the first byte and the ISR blew out to 68uS.
WTF?
It seems that the compiler has decided that "(PINB >> PB4) & 1" will be the same for all three times and has not bothered repeating the code, presumably did that once at the start of the ISR and just did assignments thereafter. If I'd had the other Arduino hooked up I would have realised I was getting duff data, but with MISO unconnected FF is as expected and I didn't look into it.
As I don't know if you can make PINB volatile I made the variables being assigned volatile instead and that seems to work.
So the C version takes 68uS, nearly twice as slow as assembler (thank goodness, the every foundations of my world had taken a beating for a minute there) but not too shabby.
______
Rob
« Last Edit: February 16, 2011, 04:29:07 am by Graynomad » Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
