Topic: NONIN Pulse Oximeter (OEM III) Module to Finger Probe (Read 3531 times) previous topic - next topic
moomoo
Hey peeps, i ordered a NONIN Pulse Oximeter from overseas like 5 weeks back.
Attached below is the module specs & technical information:
http://www.nonin.com/documents/OEM%20III%20Module%20Specifications.pdf
After knowing how to connect my Arduino Pro Mini to the Pulse Oximeter module, i realised I do not know how to connect the finger probe to the Pulse Oximeter module.
It is Page 10 under SENSOR CONNECTION. I do not know which pins to connect.
Appreciate lots for your help!!!! :)
fliggygeek
Can you post a link to the device you are attempting to connect this to?
"Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent di
moomoo
Sorry, which link do u need? The finger probe, arduino pro mini or the nonin oem module?
moomoo
The finger probe that we will be using will be Nonin 8000J Flex to connect to the Nonin OEM module. I am uncertain of the connections for the finger probe to the OEM module.
Under SENSOR CONNECTION:
J1-01 7 Cable Shield     Cable shield
J1-02 5 Coax Signal      Photo diode signal
J1-04 9 Coax Shield      Photo diode bias
J1-05 6 Green             Sensor type #1 line
J1-06 2 Red                LED drive line
J1-07 3 Black              LED drive line
J1-12 1 Yellow            Sensor type #2/1 wire
These are pins to connect the sensors, so I am not sure whether which pins i should connect it to...
