#include <HardwareSensor.h>
//writen for the touchshield slide
//draws current/peak and a bar graph for:
// x
// y
// bst
// IC F
// Turbo F
//debug notes:
//showing max then 0 then max then 0?? with no sensors plugged in and with sensors pluggedin
//shows value then 0 then value...
////comms issue - getting sent 0 and then getting sent real value (arduino code fix)
////comms issue - packing 0 into the var that is getting sent out (arduino code)
////comms error - between checking which sensor it is and then grabbing that value there is an error
//// but the buffer should aready have that value
//with sensors plugged in:
//boost 35 or 32 (not sure why...suspect missing something or other)
///boost also looks like it is matching the t2 output for some odd reason...even with no sensor present
//x and y both at 0
//t1 and t2 are working in their full range (warm hand test)
float boost = 0;
float temp1 = 0;
float temp2 = 0;
float accelx = 0, accely = 0;
float o_x = 160;
float o_y = 160;
float x_peak_neg = 0;
float x_peak_pos = 0;
float y_peak_neg = 0;
float y_peak_pos = 0;
float peak_boost = 0;
float peak_temp1 = 0;
float peak_temp2 = 0;
float o_boost = 0;
float o_temp1 = 0;
float o_temp2 = 0;
int maxBoost = 25;
int maxT1 = 300;
int maxT2 = 300;
int warnBoost = 21;
int warnT1 = 200;
int warnT2 = 200;
int severeBoost = 23;
int severeT1 = 300;
int severeT2 = 300;
void setup(){
Sensor.begin(19200);
background(0); //black background
//draw the rectangles and labels
//-spacing should be 40 pixels tall for each rectangle
//-all rects start at 50 and go 2xx pixels widen
//-all rects are 44 high
fill(0,0,0);
stroke(255,0,0);
rect(50,4,220,42);
rect(50,52,220,42);
rect(50,100,220,42);
rect(50,148,220,42);
rect(50,196,220,42);
//bar labels
text("boost",8,22,8);
text("x",20, 52+20,18);
text("y",20,100+20,18);
text("t1",14,148+20,18);
text("t2",14,196+20,18);
//get the readings from the arduino
void loop(){
gettouch(); //update the mouse coordinates
//add section to reset peaks on touch per area
//change the below section so that it updates in a nicer/more efficient manner
if (Sensor.available()){
int value;
value = Sensor.read();
if (strcmp(Sensor.getName(), "x")) {
accelx = value/100; //get the sensor value
if ((accelx > x_peak_pos) && (accelx > 0)){
x_peak_pos = accelx;
if ((accelx < x_peak_neg) && (accelx < 0)){
x_peak_neg = accelx;
print_values_x();
//draw_bars_x();
if (strcmp(Sensor.getName(), "y")) {
accely = value/100; //get the sensor value
if ((accely > y_peak_pos) && (accely > 0)){
y_peak_pos = accely;
if ((accely < y_peak_neg) && (accely < 0)){
y_peak_neg = accely;
print_values_y();
//draw_bars_y();
if (strcmp(Sensor.getName(), "t1")) {
temp1 = value; //get the sensor value
if (temp1 > peak_temp1){
peak_temp1 = temp1;
print_values_t1();
//draw_bars_t1();
if (strcmp(Sensor.getName(), "t2")) {
temp2 = value; //get the sensor value
if (temp2 > peak_temp2){
peak_temp2 = temp2;
print_values_t2();
//draw_bars_t2();
if (strcmp(Sensor.getName(), "bt")){
boost = value;
if (boost > peak_boost){
peak_boost = boost;
print_values_boost();
//draw_bars_boost();
//for debuging the display without the comms stuff/without sensors
/*boost = boost + random(2);
accelx = accelx + .01;
accely = accely + .01;
temp1 = temp1 + random(2);
temp2 = temp2 + random(2); */
//avoid flicker as much as possible by only redrawing when there is a change
//skip the accel readings because they will jump all over the place anyways?
o_boost = boost;
o_temp1 = temp1;
o_temp2 = temp2;
o_x = abs(accelx);
o_y = abs(accely);
//TODO split this into many functions
void print_values_boost(){
fill(0,0,0);
stroke(0,255,255); //light blue
//current
text(boost,274,4+6);
//peak
text(peak_boost,274,30);
void print_values_x(){
fill(0,0,0);
text(accelx,274,52+6);
text(x_peak_pos,274,52+20);
text(x_peak_neg,274,52+30);
void print_values_y(){
fill(0,0,0);
text(accely,274,100+6);
text(y_peak_pos,274,100+20);
text(y_peak_neg,274,100+30);
void print_values_t1(){
fill(0,0,0);
text(temp1,274,148+6);
text(peak_temp2,274,196+26);
void print_values_t2(){
fill(0,0,0);
text(temp2,274,196+6);
text(peak_temp1,274,148+26);
void draw_bars_boost(){
float twidth=0;
//boost
if(boost != o_boost){
fill(0,255,0); //green
stroke(0,255,0);
if (boost > warnBoost){
fill(255,255,0);
stroke(255,255,0);
if (boost > severeBoost){
fill(255,0,0);
stroke(255,0,0);
twidth=218/maxBoost*boost;
rect(51,5,twidth,40);
if (o_boost >= boost){
stroke(0,0,0);
fill(0,0,0);
rect(twidth+1+51,5,218-twidth,40);
//x and y will be displayed as positive only (absolute value) in the bar graph
//they will be light blue and have no warning/severe values
void draw_bars_x(){
//x
float twidth=0;
fill(0,255,255); //light blue
stroke(0,255,255);
twidth = 218/200*abs(accelx*100);
rect(51,53,twidth,40);
if(o_x >= abs(accelx)){
stroke(0,0,0);
fill(0,0,0);
rect(twidth+1+51,53,218-twidth-1,40);
void draw_bars_y(){
//y
float twidth=0;
stroke(0,255,255);
twidth=218/200*abs(accely*100);
rect(51,101,twidth,40);
if (o_y >= abs(accely)){
stroke(0,0,0);
fill(0,0,0);
rect(twidth+1+51,101,218-twidth-1,40);
void draw_bars_t1(){
//t1
float twidth=0;
if (temp1 != o_temp1){
stroke(0,255,0);
if (temp1 > warnT1){
fill(255,255,0);
stroke(255,255,0);
if (temp1 > severeT1){
fill(255,0,0);
stroke(255,0,0);
twidth = temp1;
rect(51,149,twidth,40);
if (o_temp1 >= temp1){
stroke(0,0,0);
fill(0,0,0);
rect(twidth+1+51,149,218-twidth,40);
void draw_bars_t2(){
//t2
float twidth=0;
if (temp2 != o_temp2){
stroke(0,255,0);
if (temp2 > warnT2){
fill(255,255,0);
stroke(255,255,0);
if (temp2 > severeT2){
fill(255,0,0);
stroke(255,0,0);
twidth = temp2;
rect(51,197,twidth,40);
if (o_temp2 >= temp2){
stroke(0,0,0);
fill(0,0,0);
rect(twidth+1+51,197,218-twidth,40);
