Topic: IDE support for Ai-Thinker A9G GPRS + GPS board (Read 7725 times) previous topic - next topic
zeemankay
Jan 22, 2018, 05:47 pm Last Edit: Jan 22, 2018, 05:52 pm by zeemankay
Anybody have IDE support for Ai-Thinker A9G board?
http://wiki.ai-thinker.com/gprs/a9g/boards
They already provide C SDK but not sure how to integrate to Arduino IDE.
https://github.com/Ai-Thinker-Open/GPRS_C_SDK
Any guide to create the hardware driver to connect to IDE is much appreciated.
Cheers...
pert
Here's the definitive reference:
https://github.com/arduino/Arduino/wiki/Arduino-IDE-1.5-3rd-party-Hardware-specification
I recommend you also use other hardware packages as a guide.
You might also find this useful if you want to add support for Boards Manager installation:
https://github.com/arduino/Arduino/wiki/Arduino-IDE-1.6.x-package_index.json-format-specification
As you work through the process feel free to come back here with specific questions.
mrrcomp
Hi
I'm about to get the a9g module . Did you get this working in the ide?  Any info / code you have on integrating it with arduino that you can share will be greatly appreciated.
Regards
Meir
jumpjack
any news?
I purchased a dev board with SD-Card but without documentation, any tip?
https://www.ebay.de/itm/AI-Thinker-GPS-BDS-GPRS-A9G-Board-32Mbit-C-SDK-GPIO-UART-ADC-I2C-SPI-MQTT-TFCard-/282891177801
vidalv
Hello users of the 32u4-A9G, to use this module with the Arduino IDE, you can select the Arduino Leonardo card, it uses an ATmega32u4 identical to that of the A9G card.
Then you can take inspiration from the codes of the Hackaday website: https://hackaday.io/search?term=A9G.
I translated AI-Thiker's A9G datasheet from Chinese to French, but it's easily retranslatable into English for those interested.
The most important thing in using this product is that for it to work well you have to wait for the A9G to start (several seconds) the best is to test your code with a command AT.
Good debug!
Vincent.
