Topic: What IDE for Library Development? (Read 3236 times) previous topic - next topic
victorf
I hope I have the proper forum for this question.
I want to develop several libraries and would like to know what IDE is used to develop the code?
Any enlightenment will be appreciated.
Vic
avenue33
Hi!
The Arduino IDE is perfect for library development.
Check here for a complete tutorial.
Enjoy  ;)
JanD
The Arduino IDE works for library development, but to make one, you MUST have a .pde file. You could then use the left pointing arrow at the top left side and then choose New Tab. Then you can choose a file name and the wanted extension (.h or .cpp). As sad, this MUST have an .pde file. If you don't want that you can use another IDE like Qt Creator or Eclipse. I use Qt Creator and it works great. There is one commercial and one non-commercial version available of the Qt Creator.
Hi!
Enjoy  ;)
That tutorial is of course good.
ALWAYS remember you must put #include <WProgram.h> on top of both your header file and source file.
JanD
mowcius
Heh, stick to simple - notepad works fine :)
frank26080115
NetBeans or Eclipse
once you know how to use them, you'll never go back to Arduino's IDE
JanD
NetBeans or Eclipse
I can't say the your right. Eclipse and Qt Creator (I haven't heard of NetBeans) are much better than the Arduino IDE, but you can't upload from them. There is an AVR plugin for Eclipse, but it doesn't work (easy) with the Arduino core files.
So for library development; you are right. For Arduino program development, you are wrong.
JanD
frank26080115
Just make a makefile that does everything the Arduino IDE does, one of the old Arduino versions even came with one. The core files are just a bunch of files that gets compiled and linked along with your own files. Also make sure your makefile includes the AVRDUDE command.
Or use Eclipse or NetBeans with Arduino in external editor mode, do anything to avoid typing in that thing.
graynomad
I use Netbeans and run a makefile from within it. No IDE required and no swapping to a DOS window.
Having said that using Notepad and swapping to a DOS window to run the makefile is a good way to go as well.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
jmrobert
windows only: crimson editor
linux/win cross: scite
uploading is just avrdude, learn the cmd line and you can upload from anything that allows user tools to be added.
