Topic: Robot chassis first test (Read 1 time) previous topic - next topic
UnaClocker
http://www.youtube.com/watch?v=0hAjB8jpdzM
It's one of those cheap 4wd skidsteer chassis from China, I built a pair of H-Bridges with TIP122/TIP127 chips. In the video, I just have it run through the pre-programmed moves as a bit of a functionality test. I have no sensors on the unit yet.
And here's the sketch:
Code: [Select]
/*  Brian's TeensyBot sketch. 4wd SkidSteer chinese robot Chassis
    Teensy++ microcontroller
    Driver's Side Motor IO Pins:
    14 - Backwards
    15 - Forwards
    Passenger Side Motor IO Pins:
    25 - Forwards
    26 - Backwards
14,15,25 and 26 are PWM capable pins.
  pinMode(6, OUTPUT);  // Onboard LED
  pinMode(14, OUTPUT);
  pinMode(15, OUTPUT);
  pinMode(25, OUTPUT);
  pinMode(26, OUTPUT);
void goForward() {
  // Assuming allStop was called before this - Maybe I should call it from here, first?
  digitalWrite(15, HIGH);
  digitalWrite(25, HIGH);
void goBackward() {
  // Again, assume all stopped before this
  digitalWrite(14, HIGH);
  digitalWrite(26, HIGH);
void allStop() {
  digitalWrite(14, LOW);
  digitalWrite(15, LOW);
  digitalWrite(25, LOW);
  digitalWrite(26, LOW);
  digitalWrite(6, LOW); // onboard LED
void goLeft() {
  // Slight left turn
void goRight() {
void clockwise() {
  // Driver's side forward, pass side backward
void counterClockwise() {
  allStop();
  delay(100);
  digitalWrite(6, HIGH);
  goForward();
  delay(1500);
  allStop();
  delay(450);
  goBackward();
  delay(1500);
  allStop();
  delay(450);
  goLeft();
  delay(750);
  goForward();
  delay(750);
  allStop();
  delay(450);
  goRight();
  delay(750);
  goForward();
  delay(750);
  allStop();
  delay(450);
  clockwise();
  delay(750);
  allStop();
  delay(450);
  counterClockwise();
  delay(750);
  allStop();
  delay(300);
Brian from Tacoma, WA
Arduino evangelist - since Dec, 2010.
Nikka93
Onions
It is looking good!
I almost built a robot as a first project, but I could not find any wheels. I had the motors, arduino and a piece of MDF to screw the motors onto, as well as some microswitches as sensors, and all the code. The only problem was, I had no way to connect the wheels to the motors!   :0  Microswitches are good as sensors as they require very little operating force. By suspending them out on springs or something similar, you can have the sensors stopping the robot before it hits the wall.
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) :D
cr0sh
It is looking good!
You didn't have any 2-part epoxy or similar? Seriously, there are a TON of ways to connect wheels to motor shafts...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
