Loading...
Pages: [1]   Go Down
Author Topic: Using timer1 and 2 for great PCM Drums (6 voices)  (Read 1245 times)
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Edit: this project was updated and moved to: https://github.com/Beat707/BeatVox
So, I updated my code and now I got 6 voices using Pins 9 and 10 PWM. Thanks to the Timer1 16-bit I was able to get near 10-bit resolution, so I could just mix 3 8-bit voices without having to apply any / which would reduce audio-quality.
The example includes a simple loop I created in the Loop() area. ;-)
Timer2 was used to read samples, while Timer1 does the PWM at near 10-bits.
Just "mix" the output of Pins 9 and 10, add 10k resistors and a filter (capacitor) which I don't know the value yet, sorry.
Download files:
http://www.wusik.com/arduino/Libraries/Multi_PCM/Sound_Test_16Bits.pde
http://www.wusik.com/arduino/Libraries/Multi_PCM/PCM_Data.h
Please, contribute to the project at: http://arduino.wusik.com
Code:
  Created by WilliamK @ Wusik Dot Com (c) 2011 - http://arduino.wusik.com
  Code excerpts from: http://www.arduino.cc/playground/Code/PCMAudio - Michael Smith <michael@hurts.ca>
  8-Bit PCM Sound using PWM on Pin 9 and Pin 10 - Uses the 16-Bit timer to sum 3 voices in each Pin
  Uses Timer2 and Timer1
#include <stdint.h>
#include <avr/interrupt.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <EEPROM.h>
#include "PCM_Data.h"
#define SAMPLE_RATE 32000
unsigned int sample[6] = {2047,2047,2047,2047,2047,2047};
unsigned long mixer[2] = {0,0};
byte inByte = 0;
    Serial.println("Type 1 to 6 for Sample Playback");
    pinMode(9,OUTPUT);
    pinMode(10,OUTPUT);
    // 16 Bit Timer Setup //
    // 16000000 (CPU CLOCK) / 765 (near 10 Bits) = 20.9khz (put a filter to remove anything above 16khz) //
    TCCR1A = _BV(COM1A1) | _BV(COM1B1) | _BV(WGM11);
    TCCR1B = _BV(WGM12) | _BV(WGM13) | _BV(CS10);
    ICR1 = 765;
    OCR1A = (128*3);
    OCR1B = (128*3);
      Timer 1 Registers - ATmega328 Datasheet Page 113 (16 Bit Timer)
      Bit        7       6       5       4       3      2      1      0
      TCCR1A = COM1A1  COM1A0  COM1B1  COM1B0    R      R    WGM11  WGM10
      TCCR1B = ICNC1   ICES1   R       WGM13   WGM12  CS12   CS11   CS10
      COM1A = Out Pin 9
      COM1B = Out Pin 10
      WGM12 WGM10 = Mode 5 Fast PWM 8 Bits
      WGM12 WGM11 WGM10 = Mode 7 Fast PWM 10 Bits
      WGM13 WGM12 WGM11 = Mode 14 Fast PWM Top=ICR1
      CS10 = No PreScaler
    // Timer 2 - used to load Samples //
    startTimer();
  sample[0] = 0 ;
  delay(255);
  sample[2] = 0 ;
  delay(255);
  sample[0] = 0 ;
  sample[1] = 0 ;
  delay(255);
  sample[2] = 0 ;
  delay(255);
  sample[0] = 0 ;
  delay(255);
  sample[2] = 0 ;
  delay(255);
  sample[0] = 0 ;
  sample[1] = 0 ;
  delay(255/2);
  sample[2] = 0 ;
  delay(255/2);
  sample[3] = 0 ;
  delay(255/2);
  sample[4] = 0 ;
  delay(255/2);
  if (Serial.available() > 0)
    inByte = Serial.read();
    switch (inByte)
      case '1':
      case '2':
      case '3':
      case '4':
      case '5':
      case '6':
        sample[inByte-'1'] = 0 ;
ISR(TIMER2_COMPA_vect)
  if (sample[0] < 2047) { mixer[0]  = (unsigned int)pgm_read_byte(&PCM_Data[0][sample[0]]); sample[0]++; } else mixer[0] = 128;
  if (sample[1] < 2047) { mixer[0] += (unsigned int)pgm_read_byte(&PCM_Data[1][sample[1]]); sample[1]++; } else mixer[0] += 128;
  if (sample[2] < 2047) { mixer[0] += (unsigned int)pgm_read_byte(&PCM_Data[2][sample[2]]); sample[2]++; } else mixer[0] += 128;
  if (sample[3] < 2047) { mixer[1]  = (unsigned int)pgm_read_byte(&PCM_Data[3][sample[3]]); sample[3]++; } else mixer[1] = 128;
  if (sample[4] < 2047) { mixer[1] += (unsigned int)pgm_read_byte(&PCM_Data[4][sample[4]]); sample[4]++; } else mixer[1] += 128;
  if (sample[5] < 2047) { mixer[1] += (unsigned int)pgm_read_byte(&PCM_Data[5][sample[5]]); sample[5]++; } else mixer[1] += 128;
  OCR1A = mixer[0];
  OCR1B = mixer[1];
void startTimer()
    TCCR2A = 0;
    TCCR2B = 0;
    bitWrite(TCCR2A, WGM21, 1);
    bitWrite(TCCR2B, CS20, 1);
uint32_t ocr = F_CPU / SAMPLE_RATE - 1;
uint8_t prescalarbits = 0b001;
if (ocr > 255)
ocr = F_CPU / SAMPLE_RATE / 8 - 1;
prescalarbits = 0b010;
if (ocr > 255)
ocr = F_CPU / SAMPLE_RATE / 32 - 1;
prescalarbits = 0b011;
if (ocr > 255)
ocr = F_CPU / SAMPLE_RATE / 64 - 1;
prescalarbits = 0b100;
if (ocr > 255)
ocr = F_CPU / SAMPLE_RATE / 128 - 1;
prescalarbits = 0b101;
if (ocr > 255)
ocr = F_CPU / SAMPLE_RATE / 256 - 1;
prescalarbits = 0b110;
if (ocr > 255)
ocr = F_CPU / SAMPLE_RATE / 1024 - 1;
prescalarbits = 0b111;
if (ocr > 255)
return;
TCCR2B = prescalarbits;
OCR2A = ocr;
bitWrite(TIMSK2, OCIE2A, 1);
« Last Edit: April 03, 2013, 08:52:36 am by WilliamK Govinda » Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Actually, since my "mentor" told me I could do it, I managed to get everything done with a single timer.  smiley-eek-blue
Now it uses the 16-bit timer instead for everything.
Code:
  8-Bit PCM Sound using PWM on Pin 9 and Pin 10 - Uses the 16-Bit Timer1 to sum 3 voices in each Pin
#include <stdint.h>
#include <avr/io.h>
#include <EEPROM.h>
unsigned long mixer[2] = {(128*3),(128*3)};
byte inByte = 0;
    pinMode(9,OUTPUT);
    pinMode(10,OUTPUT);
    // 16000000 (CPU CLOCK) / 760 (10 Bits) = 21052 samples-per-second (put a filter to remove anything above 10.5khz)
    TCCR1A = _BV(COM1A1) | _BV(COM1B1) | _BV(WGM11); // Fast PWM Timer on Pins 9 and 10
    TCCR1B = _BV(WGM12) | _BV(WGM13) | _BV(CS10); // Non-Phase Inverting - No Prescaler
    ICR1 = 760; // Max value of 760 (9-bits is 511 and 10-bits is 1023)
    TIMSK1 = _BV(TOIE1); // timer overflow interrupt
    sei(); // enable global interrupts
    OCR1A = (128*3); // Initial PWM Pin 9
    OCR1B = (128*3); // Initial PWM Pin 10
    switch (inByte)
      case '1':
      case '2':
      case '3':
      case '4':
      case '5':
      case '6':
ISR(TIMER1_OVF_vect)
  // Do this first so the PWM is updated faster //
  OCR1A = mixer[0];
  OCR1B = mixer[1];
  // Now Calculate the next sample //
I just need to re-do the samples now...
Wk
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
The next step is to try a 256k External EEPROM and see if I can read it fast enough. ;-) If this works, it would be possible to add 8-bit sound to the Wusik Arduino Drum Machine!  smiley-sweat  smiley-fat
Wk
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Nah, the EEPROM is not fast enough, its only 400khz, while we would need something faster.
Now I wonder about another thing, creating a sine/saw/pulse based oscillator controlled via midi. I wonder if I would be able to get 6 voices, or if I would need to build a wavetable and read like drum sounds instead.
Not sure when I will have some extra free time to work on this, but I'm sure curious to see what could be done with this idea. ;-)
Wk
Logged
Offline Offline
Full Member
View Profile
so all I need for this test example is 2 speakers connected to ground and pins 9 and 10? Oh and a capacitor connected in series?
And what do you mean by drums? Just drum sounds or what? Can I produce tones of music notes?
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
You could just use a Resistor, 10K, for each Pin, them merge both 10K into a single speaker. The Capacitor is to filter high-frequencies out, but it still sound great without it, haven't even tested with it yet. ;-)
Wk
Logged
Offline Offline
Newbie
View Profile
Check out this site: http://sensorium.github.com/Mozzi/
It's got great synthesis stuff for arduino. We tried it out, and theres some cool sounds in it.
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Oh, very nice, thank you!  smiley-cool
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Actually, this whole project is now on http://beat707.com/ and its called BeatVox, and has a GitHub url now.
Logged
Pages: [1]   Go Up
Print
Jump to:
