Topic: Nuvoton ISD1700 Chip (Read 14197 times) previous topic - next topic
anchan
I have been trying desperately to get talk to the Nuvoton ISD1700 Chip with an Arduino Pro 328 - 5V/16Mhz board.  I found this thread, but even on the new forum it is read-only http://arduino.cc/forum/index.php/topic,37348.0
First off, thank you the poster from that thread who wrote such wonderful code.  Unfortunately, I have not been able to get it to work.  All I can get from the Serial Monitor is "Not_RDY"
Everything compiled OK.  I have an identical ISD1700 hooked up in button mode, and works fine.  I swapped the chips, and its not the chip.
Has anyone worked on this recently?  Not sure where to start.
Thanks
eforman
maybe post a picture of your breadboard?
anchan
Attached are a few photos of the breadboard.  I'm not sure exactly what you could really determine from the photos, but its all worth a shot.
I have the ISD1700 hooked up exactly as in example 2 (page 17) of the datasheet with a few exceptions:
http://www.nuvoton.com/hq/enu/ProductAndSales/ProductLines/ConsumerElectronicsIC/ISDVoiceIC/ISDChipCorder/Documents/ISD1700.pdf
The exception is that I am not using the Analn as shown there, but rather have a mic hooked up as in example 1 (page16) of the datasheet.
Also, I am supplying power to the chip from VCC and GND of the arduino, which is getting power from USB at the moment.
Also, I have a 100 ohm resistor in series with the speaker just to be safe, since I don't believe USB can drive an 8 ohm speaker.
If I put my ear right up against the speaker, I can hear a tiny bit of background noise, so I know it is on.  Plus the LED connected to Pin 2 of the chip is lit.
I will keep plugging away, but if anyone thinks of anything let me know.  Also, don't rule out the stupidest of suggestions.  I am a total newbie to the arduino, so I could have something really dumb going on.  I have other electronics experience, just not with the arduino.
Thanks in advance.
anchan
OK, I just realized a really stupid mistake.  I had pin 1 attached to ground not power!  Well, anyway, now when I type the letter R or P or whatever into serial monitor, I get "Status--->CMD_ERR PU RDY".
On the arduino platform, I get the following errors:
Error inside Serial.serialEvent()
java.io.IOException: Bad file descriptor in nativeavailable
   at gnu.io.RXTXPort.nativeavailable(Native Method)
   at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532)
   at processing.app.Serial.serialEvent(Serial.java:215)
   at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
   at gnu.io.RXTXPort.eventLoop(Native Method)
   at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
anchan
And a bit more info:
Restarting my machine got rid of the java IO error messages.  But I still get "CMD_ERR PU RDY" whenever I enter a command.
I put a scope on Pin 13 of the arduino which according to the .h should be SCK.  I was assuming I would see some kind of clock output there, but instead its just at a solid +5.
anchan
Well, last one.
I uploaded the attached starter code I had from another source, and this DOES WORK.
I'm assuming the other code, which is much more polished and which I would love to use, is maybe written for a different arduino, because I just can't get it to work.
All for now.  Thanks
neuron_upheaval
The ISD1700 library is Arduino-Duemilanove compatible, so it should be okay with Arduino Pro.
Maybe there is a problem with the library itself, even if it is compiled okay.
I'll check it out.
Cheers,
nu
neuron_upheaval
#7
Mar 17, 2011, 12:12 pm Last Edit: Mar 17, 2011, 07:37 pm by neuron_upheaval Reason: 1
Please try this ISD1700.cpp below and see if it works. I changed the SPI mode. Now it is just like the Spi library that was used in your functioning code from post #5.
ISD1700.cpp
Code: [Select]
 ISD1700.cpp - Library for Nuvoton ISD1700 chipcorders
 Copyright (c) 2009 Marcelo Shiniti Uchimura.
 Author: Marcelo Shiniti Uchimura, CITS, <www.cits.br>
 Version: March 17, 2011
 This library is free software; you can redistribute it and/or
 modify it under the terms of the GNU Lesser General Public
 License as published by the Free Software Foundation; either
 version 2.1 of the License, or (at your option) any later version.
 This library is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
 Lesser General Public License for more details.
 You should have received a copy of the GNU Lesser General Public
 License along with this library; if not, write to the Free Software
 Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
* Includes
#include "WProgram.h"
#include "ISD1700.h"
* Definitions
* Constructor
* Based on Cam Thompson's Spi library
ISD1700::ISD1700(uint8_t SSPin)
 uint8_t dummy;
 _SSPin = SSPin;
 // initialize SPI communication
 pinMode(SCK_PIN, OUTPUT);
 pinMode(MOSI_PIN, OUTPUT);
 pinMode(MISO_PIN, INPUT);
 pinMode(_SSPin, OUTPUT);
 SPCR = (1<<SPE) | (1<<MSTR);
 dummy = SPSR;
 dummy = SPDR;
 digitalWrite(_SSPin, HIGH);
 // initialize private vars
 _SR0 = 0;      // Status Register #0                   uint16_t <15:0>
 _SR1 = 0;      // Status Register #1                   uint8_t  <7:0>
 _APC = 0;      // Analog Path Configuration Register   uint16_t <11:0>
 _PP = 0;       // Playback Pointer                     uint16_t <10:0>
 _RP = 0;       // Record Pointer                       uint16_t <10:0>
 _DEVICEID = 0; // Device Identification Register       uint8_t  <7:3>
 // reset chipcorder
 reset();
* Transfer data to SPI peripheral slaves
uint8_t ISD1700::spi_transfer(uint8_t data)
 SPDR = data;
 while (!(SPSR & (1<<SPIF)));
 return SPDR;
* Send a command to chipcorder
void ISD1700::sendCmd(uint8_t cmd)
 uint8_t data[4] = {0xFF,0xFF,0xFF,0xFF};
 digitalWrite(_SSPin, LOW);
 data[0] = spi_transfer(cmd);
 data[1] = spi_transfer(0);
 switch(cmd)
   case 0x05:                     // RD_STATUS
     case 0x09:                     // DEVID
       data[2] = spi_transfer(0);
     case 0x06:                     // RD_PLAY_PTR
     case 0x08:                     // RD_REC_PTR
     case 0x44:                     // RD_APC
       data[3] = spi_transfer(0);
 _SR0 = word(data[1],data[0]);
 switch(cmd)
       _SR1 = data[2];
       _PP = word(data[3],data[2]);
       _RP = word(data[3],data[2]);
     case 0x09:    // DEVID
       _DEVICEID = data[2];
       _APC = word(data[3],data[2]);
* plus one 12-bit parameter
* Usage is valid for the following commands:
*   WR_APC1
*   WR_APC2
void ISD1700::sendCmd(uint8_t cmd, uint16_t apc)
 uint8_t data[3] = {0xFF,0xFF,0xFF};
 // check if it is either WR_APC1 or WR_APC2 instruction
 // exit otherwise
 if(cmd != 0x45 && cmd != 0x65)
     return;
 data[1] = spi_transfer( (uint8_t)(apc & 0xFF) );
 data[2] = spi_transfer( (uint8_t)(apc>>8) );
 _SR0 = word(data[1],data[2]);
* plus two 11-bit parameters
*   SET_PLAY
*   SET_REC
*   SET_ERASE
void ISD1700::sendCmd(uint8_t cmd, uint16_t startAddr, uint16_t endAddr)
 uint8_t data[2] = {0xFF,0xFF};
 // check if it is either SET_PLAY, SET_REC, or SET_ERASE instruction
 // if not, exit method
 if(cmd != 0x80 && cmd != 0x81 && cmd != 0x82)
     return;
 data[0] = spi_transfer( (uint8_t)(startAddr & 0xFF) );
 data[1] = spi_transfer( (uint8_t)(startAddr>>8) );
 data[0] = spi_transfer( (uint8_t)(endAddr & 0xFF) );
 data[1] = spi_transfer( (uint8_t)(endAddr>>8) );
 data[0] = spi_transfer(0);
* Status flags
uint8_t ISD1700::RDY(void)
 rd_status();
 return (_SR1 & 1);
uint8_t ISD1700::ERASE(void)
 rd_status();
 return (_SR1 & 2);
uint8_t ISD1700::PLAY(void)
 rd_status();
 return (_SR1 & 4);
uint8_t ISD1700::REC(void)
 rd_status();
 return (_SR1 & 8);
uint8_t ISD1700::SE1(void)
 rd_status();
 return (_SR1 & 16);
uint8_t ISD1700::SE2(void)
 rd_status();
 return (_SR1 & 32);
uint8_t ISD1700::SE3(void)
 rd_status();
 return (_SR1 & 64);
uint8_t ISD1700::SE4(void)
 rd_status();
 return (_SR1 & 128);
uint8_t ISD1700::CMD_ERR(void)
 return (uint8_t)(_SR0 & 1);
uint8_t ISD1700::FULL(void)
 return (uint8_t)(_SR0 & 2);
uint8_t ISD1700::PU(void)
 return (uint8_t)(_SR0 & 4);
uint8_t ISD1700::EOM(void)
 return (uint8_t)(_SR0 & 8);
uint8_t ISD1700::INT(void)
 return (uint8_t)(_SR0 & 16);
* PU Power up
void ISD1700::pu(void)
 sendCmd(0x01);
* STOP Stop
void ISD1700::stop(void)
 sendCmd(0x02);
* RESET Reset
void ISD1700::reset(void)
 sendCmd(0x03);
* CLR_INT Clear interrupt
void ISD1700::clr_int(void)
 sendCmd(0x04);
* RD_STATUS Read status
uint8_t ISD1700::rd_status(void)
 sendCmd(0x05);
 return _SR1;
* RD_PLAY_PTR Read playback pointer
uint16_t ISD1700::rd_play_ptr(void)
 sendCmd(0x06);
 return _PP;
* PD Power down
void ISD1700::pd(void)
 sendCmd(0x07);
* RD_REC_PTR Read record pointer
uint16_t ISD1700::rd_rec_ptr(void)
 sendCmd(0x08);
 return _RP;
* DEVID Read device ID register
uint8_t ISD1700::devid(void)
 sendCmd(0x09);
 return _DEVICEID;
* PLAY Play from current location
void ISD1700::play(void)
 sendCmd(0x40);
* REC Record from current location
void ISD1700::rec(void)
 sendCmd(0x41);
* ERASE Erase current message
void ISD1700::erase(void)
 sendCmd(0x42);
* G_ERASE Erase all messages except Sound Effects
void ISD1700::g_erase(void)
 sendCmd(0x43);
* RD_APC Read Analog Path Configuration register
uint16_t ISD1700::rd_apc(void)
 sendCmd(0x44);
 return _APC;
* WR_APC1 Write data <11:0> into the Analog Path Configuration register
*         with volume settings from /VOL pin
void ISD1700::wr_apc1(uint16_t apc)
 sendCmd(0x45, apc);
* WR_NVCFG Write the contents of APC register into NVCFG register
void ISD1700::wr_nvcfg(void)
 sendCmd(0x46);
* LD_NVCFG Load contents of NVCFG into the APC register
void ISD1700::ld_nvcfg(void)
 sendCmd(0x47);
* FWD Forward playback pointer to the start address of the next message
void ISD1700::fwd(void)
 sendCmd(0x48);
* CHK_MEM Check circular memory
void ISD1700::chk_mem(void)
 sendCmd(0x49);
* EXTCLK Enable/disable external clock mode
void ISD1700::extclk(void)
 sendCmd(0x4A);
* WR_APC2 Write data <11:0> into the Analog Path Configuration register
*         with volume settings from bits <2:0>
void ISD1700::wr_apc2(uint16_t apc)
 sendCmd(0x65, apc);
* SET_PLAY Play from start address to end address, or stop at EOM
*          depending on D11 of APC
void ISD1700::set_play(uint16_t startAddr, uint16_t endAddr)
 sendCmd(0x80, startAddr, endAddr);
* SET_REC Record from start address to end address
void ISD1700::set_rec(uint16_t startAddr, uint16_t endAddr)
 sendCmd(0x81, startAddr, endAddr);
* SET_ERASE Erase from start address to end address
void ISD1700::set_erase(uint16_t startAddr, uint16_t endAddr)
 sendCmd(0x82, startAddr, endAddr);
neuron_upheaval
Following ryoru feedback available at http://forum.arduino.cc/index.php?topic=96463.0, I am posting a new version of the library:
ISD1700.h
Code: [Select]
 ISD1700.h - Library for Nuvoton ISD1700 chipcorders
 Version: Jan 20, 2016
#ifndef ISD1700_h
#define ISD1700_h
#define SCK_PIN   13
#define MISO_PIN  12
#define MOSI_PIN  11
#include "Arduino.h"
class ISD1700
 private:
   uint8_t  _SSPin; // Arduino's digital pin which chipcorder is attached to
   /* status registers */
   uint16_t _SR0;      // Status Register #0                   uint16_t <15:0>
     uint8_t  _SR1;      // Status Register #1                   uint8_t  <7:0>
     uint16_t _APC;      // Analog Path Configuration Register   uint16_t <11:0>
     uint16_t _PP;       // Playback Pointer                     uint16_t <10:0>
     uint16_t _RP;       // Record Pointer                       uint16_t <10:0>
     uint8_t  _DEVICEID; // Device Identification Register       uint8_t  <7:3>
     /* private methods */
     uint8_t spi_transfer(uint8_t);
     void sendCmd(uint8_t);
     void sendCmd(uint8_t, uint16_t);
     void sendCmd(uint8_t, uint16_t, uint16_t);
 public:
   /* constructor */
   ISD1700(uint8_t);
     /* functions to enquire status */
     uint8_t RDY(void);
     uint8_t ERASE(void);
     uint8_t PLAY(void);
     uint8_t REC(void);
     uint8_t SE1(void);
     uint8_t SE2(void);
     uint8_t SE3(void);
     uint8_t SE4(void);
     uint8_t CMD_ERR(void);
     uint8_t FULL(void);
     uint8_t PU(void);
     uint8_t EOM(void);
     uint8_t INT(void);
     /* chipcorder commands */
     void     pu(void);
     void     stop(void);
     void     reset(void);
     void     clr_int(void);
     uint8_t  rd_status(void);
     uint16_t rd_play_ptr(void);
     void     pd(void);
     uint16_t rd_rec_ptr(void);
     uint8_t  devid(void);
     void     play(void);
     void     rec(void);
     void     erase(void);
     void     g_erase(void);
     uint16_t rd_apc(void);
     void     wr_apc1(uint16_t);
     void     wr_nvcfg(void);
     void     ld_nvcfg(void);
     void     fwd(void);
     void     chk_mem(void);
     void     extclk(void);
     void     wr_apc2(uint16_t);
     void     set_play(uint16_t, uint16_t);
     void     set_rec(uint16_t, uint16_t);
     void     set_erase(uint16_t, uint16_t);
#endif
neuron_upheaval
(cont'd.)
ISD1700.cpp
Code: [Select]
 Version: January 20, 2016
* Includes
* Definitions
* Constructor
 uint8_t dummy;
 _SSPin = SSPin;
 dummy = SPSR;
 dummy = SPDR;
 delay(100);
 // reset chipcorder
 reset();
 SPDR = data;
 return SPDR;
 delay(1);
 switch(cmd)
     case 0x09:                     // DEVID
 delay(100);
 switch(cmd)
       _SR1 = data[2];
     case 0x09:    // DEVID
*   WR_APC1
*   WR_APC2
 // exit otherwise
     return;
 delay(1);
 delay(100);
*   SET_PLAY
*   SET_REC
*   SET_ERASE
     return;
 delay(1);
 delay(100);
* Status flags
 rd_status();
 return (_SR1 & 1);
 rd_status();
 return (_SR1 & 2);
 rd_status();
 return (_SR1 & 4);
 rd_status();
 return (_SR1 & 8);
 rd_status();
 return (_SR1 & 16);
 rd_status();
 return (_SR1 & 32);
 rd_status();
 return (_SR1 & 64);
 rd_status();
* PU Power up
 sendCmd(0x01);
* STOP Stop
 sendCmd(0x02);
* RESET Reset
 sendCmd(0x03);
 sendCmd(0x04);
 sendCmd(0x05);
 return _SR1;
 sendCmd(0x06);
 return _PP;
* PD Power down
 sendCmd(0x07);
 sendCmd(0x08);
 return _RP;
 sendCmd(0x09);
 return _DEVICEID;
 sendCmd(0x40);
 sendCmd(0x41);
 sendCmd(0x42);
 sendCmd(0x43);
 sendCmd(0x44);
 return _APC;
 sendCmd(0x45, apc);
 sendCmd(0x46);
 sendCmd(0x47);
 sendCmd(0x48);
 sendCmd(0x49);
 sendCmd(0x4A);
 sendCmd(0x65, apc);
neuron_upheaval
(cont'd.)
Example sketch
Code: [Select]
#include <ISD1700.h>
ISD1700 chip(10); // Initialize chipcorder with
                 // SS at Arduino's digital pin 10
 Serial.println("Sketch is starting up");
 char c;
 if(Serial.available())
   /* Power Up */
   chip.pu();
   c = Serial.read();
   switch(c)
      case 'A':
        Serial.println(chip.rd_apc(), BIN);
      case 'Y':
        chip.play();
      case 'P':
        chip.stop();
      case 'E':
        chip.erase();
      case 'R':
        chip.rec();
      case 'F':
        chip.fwd();
      case 'Z':
        chip.g_erase();
      case 'I':
        Serial.println(chip.devid(), BIN);
   Serial.print("Status---> ");
   Serial.print(chip.CMD_ERR()? "CMD_ERR ": " ");
   Serial.print(chip.PU()? "PU ": " ");
   Serial.print(chip.RDY()? "RDY ": "Not_RDY");
santira
I'm trying to use this lib you (neuron_upheaval) posted in a Aduino Pro Mini without success.
SERAR
 I will use my first Arduino forum post to thank you neuron_upheaval. Your library made my life easier in my Industrial Design final bachelor project. One thing, in my project I am using the ISD 1760 with a Pro Mini and an RC522 Rdif Reader. I struggled at the beginning making them both work over SPI ( because of different SPI settings for the two chips). I fanally made it work by inserting the SPI settings line "SPCR = (1<<CPHA) | (1<<CPOL) | (1<<DORD) | (1<<SPE) | (1<<MSTR);" in every send cmnd function. Maybe this will help someone who is trying to make the ISD and another chip work toghether over SPI. Once again 10000 thanks.
chiquito112
thanks: neuron_upheaval , now it works ok !!!
laserau77
Hi Guys,
I am pretty new to Arduino and are trying to get my ISD1760 chip to be controlled using a Arduino Uno.
I have been following multiple posts from neuron_upheaval about using the ISD chips an I are yet to get it working.
neuron_upheaval has the most polished code I have found.
I just cant get it to work.
I read through your instructions a few times and have everything wired correctly but I am not sure what I have done wrong.
It looks like it should work but nothing ever happens when I send the commands.
I get this on the serial monitor when I send the Erase command:
Status--->   RDY
Erase
Status--->  PU Not_RDY
Status--->   RDY
If I use the ISD1700 by the buttons it works fine, no problem it is just getting it to work through the Arduino SPI interface.
What do the replys mean?  PU means Power Up, but not sure why it gives Power Up not Ready.
When I deliberately send the wrong message I get a different answer so I know something is happening.
I have also tried the codes listed here http://forum.arduino.cc/index.php?topic=96463.0
They look promising but wont verify as are full of errors.
Is anyone able to help me work out what I have done wrong please?
