Author Topic: Nuvoton ISD1700 Chip  (Read 3028 times)
I have been trying desperately to get talk to the Nuvoton ISD1700 Chip with an Arduino Pro 328 - 5V/16Mhz board.  I found this thread, but even on the new forum it is read-only http://arduino.cc/forum/index.php/topic,37348.0
First off, thank you the poster from that thread who wrote such wonderful code.  Unfortunately, I have not been able to get it to work.  All I can get from the Serial Monitor is "Not_RDY"
Everything compiled OK.  I have an identical ISD1700 hooked up in button mode, and works fine.  I swapped the chips, and its not the chip.
Has anyone worked on this recently?  Not sure where to start.
Thanks
maybe post a picture of your breadboard?
Attached are a few photos of the breadboard.  I'm not sure exactly what you could really determine from the photos, but its all worth a shot.
I have the ISD1700 hooked up exactly as in example 2 (page 17) of the datasheet with a few exceptions:
http://www.nuvoton.com/hq/enu/ProductAndSales/ProductLines/ConsumerElectronicsIC/ISDVoiceIC/ISDChipCorder/Documents/ISD1700.pdf
The exception is that I am not using the Analn as shown there, but rather have a mic hooked up as in example 1 (page16) of the datasheet.
Also, I am supplying power to the chip from VCC and GND of the arduino, which is getting power from USB at the moment.
Also, I have a 100 ohm resistor in series with the speaker just to be safe, since I don't believe USB can drive an 8 ohm speaker.
If I put my ear right up against the speaker, I can hear a tiny bit of background noise, so I know it is on.  Plus the LED connected to Pin 2 of the chip is lit.
I will keep plugging away, but if anyone thinks of anything let me know.  Also, don't rule out the stupidest of suggestions.  I am a total newbie to the arduino, so I could have something really dumb going on.  I have other electronics experience, just not with the arduino.
Thanks in advance.
OK, I just realized a really stupid mistake.  I had pin 1 attached to ground not power!  Well, anyway, now when I type the letter R or P or whatever into serial monitor, I get "Status--->CMD_ERR PU RDY".
On the arduino platform, I get the following errors:
Error inside Serial.serialEvent()
java.io.IOException: Bad file descriptor in nativeavailable
   at gnu.io.RXTXPort.nativeavailable(Native Method)
   at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532)
   at processing.app.Serial.serialEvent(Serial.java:215)
   at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
   at gnu.io.RXTXPort.eventLoop(Native Method)
   at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
And a bit more info:
Restarting my machine got rid of the java IO error messages.  But I still get "CMD_ERR PU RDY" whenever I enter a command.
I put a scope on Pin 13 of the arduino which according to the .h should be SCK.  I was assuming I would see some kind of clock output there, but instead its just at a solid +5.
Well, last one.
I uploaded the attached starter code I had from another source, and this DOES WORK.
I'm assuming the other code, which is much more polished and which I would love to use, is maybe written for a different arduino, because I just can't get it to work.
All for now.  Thanks
central nervous system
Causing havoc inside your brain since 1980
The ISD1700 library is Arduino-Duemilanove compatible, so it should be okay with Arduino Pro.
Maybe there is a problem with the library itself, even if it is compiled okay.
I'll check it out.
Cheers,
nu
Please try this ISD1700.cpp below and see if it works. I changed the SPI mode. Now it is just like the Spi library that was used in your functioning code from post #5.
ISD1700.cpp
  ISD1700.cpp - Library for Nuvoton ISD1700 chipcorders
  Copyright (c) 2009 Marcelo Shiniti Uchimura.
  Author: Marcelo Shiniti Uchimura, CITS, <www.cits.br>
  Version: March 17, 2011
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
 * Includes
#include "WProgram.h"
#include "ISD1700.h"
 * Definitions
 * Constructor
 * Based on Cam Thompson's Spi library
ISD1700::ISD1700(uint8_t SSPin)
  uint8_t dummy;
  _SSPin = SSPin;
  // initialize SPI communication
  pinMode(SCK_PIN, OUTPUT);
  pinMode(MOSI_PIN, OUTPUT);
  pinMode(MISO_PIN, INPUT);
  pinMode(_SSPin, OUTPUT);
  SPCR = (1<<SPE) | (1<<MSTR);
  dummy = SPSR;
  dummy = SPDR;
  digitalWrite(_SSPin, HIGH);
  // initialize private vars
  _SR0 = 0;      // Status Register #0                   uint16_t <15:0>
  _SR1 = 0;      // Status Register #1                   uint8_t  <7:0>
  _APC = 0;      // Analog Path Configuration Register   uint16_t <11:0>
  _PP = 0;       // Playback Pointer                     uint16_t <10:0>
  _RP = 0;       // Record Pointer                       uint16_t <10:0>
  _DEVICEID = 0; // Device Identification Register       uint8_t  <7:3>
  // reset chipcorder
  reset();
 * Transfer data to SPI peripheral slaves
uint8_t ISD1700::spi_transfer(uint8_t data)
  SPDR = data;
  while (!(SPSR & (1<<SPIF)));
  return SPDR;
 * Send a command to chipcorder
void ISD1700::sendCmd(uint8_t cmd)
  uint8_t data[4] = {0xFF,0xFF,0xFF,0xFF};
  digitalWrite(_SSPin, LOW);
  data[0] = spi_transfer(cmd);
  data[1] = spi_transfer(0);
  switch(cmd)
    case 0x05:                     // RD_STATUS
      case 0x09:                     // DEVID
        data[2] = spi_transfer(0);
        break;
      case 0x06:                     // RD_PLAY_PTR
      case 0x08:                     // RD_REC_PTR
      case 0x44:                     // RD_APC
        data[3] = spi_transfer(0);
        break;
  _SR0 = word(data[1],data[0]);
  switch(cmd)
        _SR1 = data[2];
        break;
        _PP = word(data[3],data[2]);
        break;
        _RP = word(data[3],data[2]);
        break;
      case 0x09:    // DEVID
        _DEVICEID = data[2];
        break;
        _APC = word(data[3],data[2]);
        break;
 * plus one 12-bit parameter
 * Usage is valid for the following commands:
 *   WR_APC1
 *   WR_APC2
void ISD1700::sendCmd(uint8_t cmd, uint16_t apc)
  uint8_t data[3] = {0xFF,0xFF,0xFF};
  // check if it is either WR_APC1 or WR_APC2 instruction
  // exit otherwise
  if(cmd != 0x45 && cmd != 0x65)
      return;
  data[1] = spi_transfer( (uint8_t)(apc & 0xFF) );
  data[2] = spi_transfer( (uint8_t)(apc>>8) );
  _SR0 = word(data[1],data[2]);
 * plus two 11-bit parameters
 *   SET_PLAY
 *   SET_REC
 *   SET_ERASE
void ISD1700::sendCmd(uint8_t cmd, uint16_t startAddr, uint16_t endAddr)
  uint8_t data[2] = {0xFF,0xFF};
  // check if it is either SET_PLAY, SET_REC, or SET_ERASE instruction
  // if not, exit method
  if(cmd != 0x80 && cmd != 0x81 && cmd != 0x82)
      return;
  data[0] = spi_transfer( (uint8_t)(startAddr & 0xFF) );
  data[1] = spi_transfer( (uint8_t)(startAddr>>8) );
  data[0] = spi_transfer( (uint8_t)(endAddr & 0xFF) );
  data[1] = spi_transfer( (uint8_t)(endAddr>>8) );
  data[0] = spi_transfer(0);
 * Status flags
uint8_t ISD1700::RDY(void)
  rd_status();
  return (_SR1 & 1);
uint8_t ISD1700::ERASE(void)
  rd_status();
  return (_SR1 & 2);
uint8_t ISD1700::PLAY(void)
  rd_status();
  return (_SR1 & 4);
uint8_t ISD1700::REC(void)
  rd_status();
  return (_SR1 & 8);
uint8_t ISD1700::SE1(void)
  rd_status();
  return (_SR1 & 16);
uint8_t ISD1700::SE2(void)
  rd_status();
  return (_SR1 & 32);
uint8_t ISD1700::SE3(void)
  rd_status();
  return (_SR1 & 64);
uint8_t ISD1700::SE4(void)
  rd_status();
  return (_SR1 & 128);
uint8_t ISD1700::CMD_ERR(void)
  return (uint8_t)(_SR0 & 1);
uint8_t ISD1700::FULL(void)
  return (uint8_t)(_SR0 & 2);
uint8_t ISD1700::PU(void)
  return (uint8_t)(_SR0 & 4);
uint8_t ISD1700::EOM(void)
  return (uint8_t)(_SR0 & 8);
uint8_t ISD1700::INT(void)
  return (uint8_t)(_SR0 & 16);
 * PU Power up
void ISD1700::pu(void)
  sendCmd(0x01);
 * STOP Stop
void ISD1700::stop(void)
  sendCmd(0x02);
 * RESET Reset
void ISD1700::reset(void)
  sendCmd(0x03);
 * CLR_INT Clear interrupt
void ISD1700::clr_int(void)
  sendCmd(0x04);
 * RD_STATUS Read status
uint8_t ISD1700::rd_status(void)
  sendCmd(0x05);
  return _SR1;
 * RD_PLAY_PTR Read playback pointer
uint16_t ISD1700::rd_play_ptr(void)
  sendCmd(0x06);
  return _PP;
 * PD Power down
void ISD1700::pd(void)
  sendCmd(0x07);
 * RD_REC_PTR Read record pointer
uint16_t ISD1700::rd_rec_ptr(void)
  sendCmd(0x08);
  return _RP;
 * DEVID Read device ID register
uint8_t ISD1700::devid(void)
  sendCmd(0x09);
  return _DEVICEID;
 * PLAY Play from current location
void ISD1700::play(void)
  sendCmd(0x40);
 * REC Record from current location
void ISD1700::rec(void)
  sendCmd(0x41);
 * ERASE Erase current message
void ISD1700::erase(void)
  sendCmd(0x42);
 * G_ERASE Erase all messages except Sound Effects
void ISD1700::g_erase(void)
  sendCmd(0x43);
 * RD_APC Read Analog Path Configuration register
uint16_t ISD1700::rd_apc(void)
  sendCmd(0x44);
  return _APC;
 * WR_APC1 Write data <11:0> into the Analog Path Configuration register
 *         with volume settings from /VOL pin
void ISD1700::wr_apc1(uint16_t apc)
  sendCmd(0x45, apc);
 * WR_NVCFG Write the contents of APC register into NVCFG register
void ISD1700::wr_nvcfg(void)
  sendCmd(0x46);
 * LD_NVCFG Load contents of NVCFG into the APC register
void ISD1700::ld_nvcfg(void)
  sendCmd(0x47);
 * FWD Forward playback pointer to the start address of the next message
void ISD1700::fwd(void)
  sendCmd(0x48);
 * CHK_MEM Check circular memory
void ISD1700::chk_mem(void)
  sendCmd(0x49);
 * EXTCLK Enable/disable external clock mode
void ISD1700::extclk(void)
  sendCmd(0x4A);
 * WR_APC2 Write data <11:0> into the Analog Path Configuration register
 *         with volume settings from bits <2:0>
void ISD1700::wr_apc2(uint16_t apc)
  sendCmd(0x65, apc);
 * SET_PLAY Play from start address to end address, or stop at EOM
 *          depending on D11 of APC
void ISD1700::set_play(uint16_t startAddr, uint16_t endAddr)
  sendCmd(0x80, startAddr, endAddr);
 * SET_REC Record from start address to end address
void ISD1700::set_rec(uint16_t startAddr, uint16_t endAddr)
  sendCmd(0x81, startAddr, endAddr);
 * SET_ERASE Erase from start address to end address
void ISD1700::set_erase(uint16_t startAddr, uint16_t endAddr)
  sendCmd(0x82, startAddr, endAddr);
« Last Edit: March 17, 2011, 01:37:51 pm by neuron_upheaval » Logged
