Topic: LIDAR B0602 Laser Scanner (Read 918 times) previous topic - next topic
plastic
hi .
I bought new LIDAR scanner . with this Specifications :
Model :B0602 level radar
Range Sampling rate :2K / s
Scanning frequency :6.2Hz
Laser wavelength :780nm
Laser power :3mW (maximum power)
Accuracy :<3% @ 5m
Drive motor :Brush Motor
Distance variance coefficient: DCV <0.2%
Communication interface RS232 (TTL)
Power consumption :1.5W
Baud rate :115200
Working current :500mA
Weight :175g ± 2g
working environment temperature :0 ℃ -45 ℃
level :0 "-1"
working environment humidity :<90% w
orking environment illumination :<1000lux
now i cant find this product datasheets , and the arduino code for run it
what should i do ?
tnx
spycatcher2k
Contact the site where you bought it and ask them! without the datasheet, you MAY ruin it, or your arduino.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
plastic
hi :
http://small-order.hktdc.com/small-order-suppliers-products/Lidar-B0602-Laser-Lidar/en/1X0A0J0F/3260476/
http://shop.aftabrayaneh.com/Lidar_B0602_360_Degree_Laser_Scanner_Positioning__AFTAB.html
spycatcher2k
Yip - my GOOGLE also found them! Why post the links here though?
Mrs Drew
robtillaart
Thanks for posting those links.
What are you going to build with the lidar?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
plastic
hi friends .
can you take links for startup the module ?
tnx
plastic
HI :
this web sites :
plastic
spycatcher2k
If you can't find the datasheet, and we cant find the datasheet, then how can anybody help?
Mrs Drew
