« Reply #5 on: February 22, 2011, 10:20:07 pm » |
@zoomKat,
thanks for the suggestion. but the arduino module i am using (ArduinoBT) has an in-built bluetooth component and so it is basically impossible to seperate the two physically(at least to the best of my knowledge).
@fliggygeek, here are the best codes. pls note that the final aim of the code is to drive 8 servos...so you will see 8 variables set up to achieve this. enjoy
#include <SoftwareSerial.h> #define rxPin 2 #define txPin 3 SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin); unsigned int FrontServo1 =0X41; // unsigned int FrontServo2 =0X42; unsigned int BackServo3 =0X43; unsigned int BackServo4 =0X44; unsigned int PanelServo5 =0X45; unsigned int MainServo6 =0X46; unsigned int MainServo7 =0X47; unsigned int MainServo8 =0X48;
//these variables won't change: const int Midpoint=732; //variable to determine angle midway of servo extremes const int rate = 100; //Variable to determine the rate of turning of servo motors const int panelPin = 2; //these variables will change int bufferIn =0; // Variable to store incoming byte byte pinState = 0; int position1 = Midpoint; int position2 = Midpoint; int position3 = Midpoint; int position4 = Midpoint; int position5 = Midpoint; int position6 = Midpoint; int position7 = Midpoint; int position8 = Midpoint;
void setup() { Serial.begin (9600); //Set USART Baud Rate to 115200 pinMode(rxPin, INPUT); pinMode(txPin, OUTPUT); mySerial.begin(9600); pinMode (panelPin, INPUT); //set panel pin as input send_cmd(FrontServo1, position1,0); /*Set the Default position of all servos in order to avoid floating*/ send_cmd(FrontServo2, position2,0); send_cmd(BackServo3, position3,0); send_cmd(BackServo4, position4,0); send_cmd(PanelServo5, position5,0); send_cmd(MainServo6, position6,0); send_cmd(MainServo7, position7,0); send_cmd(MainServo8, position8,0); } void loop() { if (Serial.available()) { // Look for char in serial que and process if found bufferIn= Serial.read(); //store char in variable switch (bufferIn) { case '1': //if char is '1' main_Forward(); //move main body forward break; case '2': //if char is '2' main_Reverse(); //move main body in reverse break; case '3': //if char is '3' main_Right(); //rotate main body to the right break; case '4': //if char is '4' main_Left(); //rotate main body to the left break; case '5': //if char is '5' while (digitalRead(panelPin) == LOW) //check the state of the panel safety pin { main_PanelDown(); // safety pin not triggered, launch main panel } main_PanelUp(); break; case 'w': //if char is 'w' front_Up(); //move front flipper upwards break; case 's': //if char is 's' front_Down(); //move front flipper downwards break; case 'd': //if char is 'd' front_Right(); //move front flipper to the right break; case 'a': //if char is 'a' front_Left(); //move front flipper to the left break; case 'i': //if char is 'i' back_Up(); //move back flipper upwards break; case 'k': //if char is 'k' back_Down(); //move back flipper downwards break; case 'j': //if char is 'j' back_Left(); //move back flipper to the left break; case 'l': //if char is 'l' back_Right(); //move back flipper to the right break; case 'x': //if char is 'x' Stop(); break; default: Serial.println("invalid command"); } } }
void front_Up() { if (position1=1463) //check if servo is at max angle, { send_cmd(FrontServo1, position1,0); // yes, Servo stays at the same position } else { position1=position1 + rate; //No, increase angle according to rate send_cmd(FrontServo1, position1,0); delay(15); // waits 15ms for the servo to reach the position } } void front_Down() { if (position1=0) //check if servo is at min angle, { send_cmd(FrontServo1, position1,0); // yes, Servo stays at the same position } else { position1=position1 - rate; //No, Decrease angle according to rate send_cmd(FrontServo1, position1,0); delay(15); // waits 15ms for the servo to reach the position } }
void front_Right() { if (position2=1463) //check if servo is at max angle, { send_cmd(FrontServo2, position2,0); // yes, Servo stays at the same position } else { position2=position2 + rate; //No, increase angle according to rate send_cmd(FrontServo2, position2,0); delay(15); // waits 15ms for the servo to reach the position } }
void front_Left() { if (position2=0) //check if servo is at min angle, { send_cmd(FrontServo2, position2,0); // yes, Servo stays at the same position } else { position2=position2 - rate; //No, Decrease angle according to rate send_cmd(FrontServo2, position2,0); delay(15); // waits 15ms for the servo to reach the position } } . . . . //same procedure repeated for the rest of the servos . . . void send_cmd(unsigned int num, unsigned int data, unsigned int ramp) //UART transmit 4 bytes: servo number, higher byte position, //lower byte position and speed
{ unsigned char higher_byte=0, lower_byte=0;
higher_byte=(data>>6)&0x003f; lower_byte=data&0x003f;
mySerial.print(num); //First byte is the servo channel 0x41-0x60 delay(2000); mySerial.print(higher_byte); //second byte is the higher byte of position //0b00xxxxxx delay(2000); mySerial.print(lower_byte); //third byte is the lower byte of position 0b00xxxxxx delay(2000); mySerial.print(ramp); //fourth byte is the speed value from 0-63 delay(2000); toggle(13);
void toggle(int pinNum) { // set the LED pin using the pinState variable: digitalWrite(pinNum, pinState); // if pinState = 0, set it to 1, and vice versa: pinState = !pinState; }
