Topic: Cam and Arduino Duemilanove project (Read 4528 times) previous topic - next topic
yuho705
I am now trying to get the picture image from the cam by using the Arduino Duemilanove.
However, I don't really know the connection between them.
Cam : C3088
http://courses.cit.cornell.edu/ee476/FinalProjects/s2009/pc389_fs256/pc389_fs256/c3088.pdf
Arduino Duemilanove
johnwasser
Looks to me like the camera has 16 data pins and a pixel clock pin to let you know when to read the data.  That's a LOT of data to read.  You'll need the datasheet for the camera chip:
http://www.cs.cmu.edu/~cmucam/Downloads/ov6620DSLF.PDF
yuho705
Thx for reply. =)
Yes. I know the camera need lots of pins. I found that some project was used this C3088 with ATmega16.
However, the Arduino Duemilanove use the ATmega328. It seems that the pins is not enough.
So, is it possible to connect them together? =(
danielaaro
If its fast enough, you might be able to use one of these(or similar)!
http://www.sparkfun.com/products/9056
It allows you to read/write many pins using a few.
johnwasser
Do you mean this project:  http://www.robozes.com/inaki/dproject/report.pdf
Looks like they read one pixel per scan line so they get one column per field.  Since there are 320 columns it will take about 11 seconds to get an entire image and, since the Arduino has no place to store that amount of data, it has to be sent to a host computer as fast as it comes in.
yuho705
Thx. But I am not familiar with this product.
After the connection, will the data from the cam be lost? or which pins can connect to the Arduino through this device??
yuho705
I will connect the SD card board for saving the data and pic. However, I still don't know is it possible to connect them together.
Deepa
Hi all,
   Please can any one tell me how can I connect a c3088 camera with to a robot made with Arduino ? Whar are the steps i need to follow.
Thanks,
Deepa
PaulS
First, tell us what you expect/hope to be able to do with this camera.
Deepa
I just wanted to take snapshots periodically. If possible i wanted to change some of the properties of the camera as brightness etc.
Thanks,
Deepa
PaulS
And do what with them? Send the data to the bit bucket? Then, why bother?
http://www.robozes.com/inaki/dproject/report.pdf might be worth a look.
liuzengqiang
With this memory extension on a mega, you can store one frame, but only one frame.  ;)
https://shop.ruggedcircuits.com/index.php?main_page=product_info&cPath=4&products_id=41
