Author Topic: Arduino <> Lobotomized Arduino <> Serial monitor  (Read 553 times)
Hello friends.
I'm trying to talk with an Arduino through another unchipped arduino.
The code is:
  pinMode(2, INPUT);
  Serial.println("send");
  if (Serial.available()) {
    Serial.read();
    Serial.println("OK");
When I connect with de chipped arduino directly with usb I get "send" every 1/2 seconds and "OK" every time I send something. PERFECT
If I connect using the unchipped arduino (gnd->gnd, vin->vin, tx->tx, rx->rx) I get "send" every 1/2 seconds and "OK" only some times. 1 every 20 times or less. It's... aleatory.
Any idea?
Thanks
Hello friends.
Now I'm getting correct answer if I get Rx signal directly from pin 1 of FTDI.
PC <-> USB <->Arduino w/o atmega <-> ftdi pin 1 <-> Chipped board rx pin
                                     tx pin     <-> Chipped board tx pin
                                     5v         <-> 5v
                                     gnd        <->  gnd
Why is this happening?
« Last Edit: February 20, 2011, 05:46:41 am by Jose Francisco » Logged
Seattle, WA USA
Seattle, WA USA
Because you now have the hardware connected correctly.
mnnn... but if I use arduino pin 0 instead of use ftdi pin 1, I can't get correct transmission.
Why can't I use tx and rx pins directly?
PD: Now I'm using a transmission based on Messenger library.
« Last Edit: February 20, 2011, 07:17:42 am by Jose Francisco » Logged
Seattle, WA USA
Seattle, WA USA
The connection from the "Arduino pin 1" to the FTDI pin is through the chip that you removed.
http://arduino.cc/it/uploads/Main/arduino-duemilanove-schematic.pdf
FTDI txd goes to R8 first, atmega pin 2 and j1 pin 0 later.
Am I wrong?
In my test, I can get signal from one side of R8 (ftdi side) but not from the other side.
I have used different arduinos with same result.
