Loading...
Pages: [1] 2 3   Go Down
Author Topic: mini Arduino idea  (Read 1987 times)
Ontario, Canada
Offline Offline
Newbie
I love Arduino
View Profile
WWW
I have thought about minimizing the Arduino board because what I found in many cases was that I didn’t need the FTDI USB interface once the sketch was loaded, and I thought the Arduino board is kind of ‘big’ for its contents.
So here is a summary of my concept of mini Arduino compatible board.  Its name will be ‘JeonLab mini.’
    * 28-pin DIP ATmega328P with Arduino bootloader
    * Digital pins from 2 to 13 are arranged on one side
    * Analog pins from 0 to 5 are arranged on the other side along with the FTDI-USB connector for an external FTDI breakout board
    * There is no reset switch, but header pins for RESET and GND are provided
    * A power LED and #13 LED
    * A 0.1uF capacitor for the auto-reset when uploading a sketch
    * Headers for power inlet (+5V and GND)
    * Small enough to fit in a small plastic box
Any comment will be appreciated.
Jeonlab
Logged
0
Offline Offline
God Member
View Profile
Hey you live in Vaughan? I'm around Dufferin and Center.
What you want to do with your design other than to fit it into a box? I don't think you'd want to experiment with a board inside a box unless you cut a hole for headers and wires to come out, and if this board is meant for experimentation, it's missing a lot of features, I think a built in v-reg is an important one (what's the point of a pretty box if there's another power supply dangling outside of it), and why would you ever leave out a reset switch?
My philosophy for designing a prototyping platform is to add features that don't take away from usability, and do not care about the cost (to a point). So add a reset switch, ISP headers, add both 5V and 3.3V power supplies, and put a ferrite bead + capacitor on the AVCC.
Also DO NOT use a 330R resistor on the pin 13 LED, you'll screw up your SCK signal if you ever decide to use SPI, try 1 kohm instead.
« Last Edit: February 17, 2011, 11:43:57 pm by frank26080115 » Logged
I'm an electrical engineering student. I designed the USnooBie (V-USB dev kit) which is sold at Seeed Studio
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
I don't see any caps for the crystal, or is that an oscilator?
A couple of mounting holes never go astray.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Why not just get a Promini?
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Or a Teensy?
(too lazy to post a picture)
Logged
0
Offline Offline
God Member
View Profile
Jeon seems to want to try making a board. Do it right and it'll be worth it. It's great to have a tool tailored to your own needs.
If you want cheap PCBs made, Itead Studio can get you 10 pieces for $28 + shipping, that's way cheaper than anything in North America or BatchPCB.
Judging from his website, he prefers resonators
I think resonators are usually used with a 1 Mohm resistor
« Last Edit: February 18, 2011, 01:40:48 am by frank26080115 » Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Where does the 1Mohm resistor go?
I have played around with layouts also, here's a minimalist 328-based board, double sided with all connections on top and the bottom being all ground plane.  I was experimenting with spare holes for other parts to see what would fit on a standard expressPCB board using all thru hole components.
« Last Edit: February 18, 2011, 02:18:34 am by CrossRoads » Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
And its schematic. Similar to a promini really but without voltage regulator.
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
I was playing with a atmega644 version also, for more IO & memory, a la ardweeny style, and as a promini style
Logged
Ontario, Canada
Offline Offline
Newbie
I love Arduino
View Profile
WWW
Thanks for all of your comments.
@frank: I live on Clark between Dufferin and Bathurst.  So close!  I also thank you for the advice on the resistor.  That's good to know.
@graynomad: The resonator (ceramic) has 2 built-in capacitors.
@crossroads: Thank you for sharing your ideas as well.
I will update some more detail soon.
Thanks.
Logged
Dresden / Germany
Offline Offline
Sr. Member
Entwicklungsklaus
View Profile
WWW
http://www.varesano.net/blog/fabio/first-picture-femtoduino-smallest-lightest-arduino-compatible-board-ever
i like it, maybe you too....
Greetings Chris
Logged
Sturmfabrik - mediale Dienstleistungen
www.sturmfabrik.de
Saint Petersburg, Russia
Offline Offline
Full Member
Amateur
View Profile
WWW
GND pin that is near RST pin. How would you plug this board to a proto-board?
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
With little, tiny, wires smiley
You'd probably want to connect it to a row of header pins, plug the pins into the protoboard.
Then make a breakout cable that matched an FTDI-basic adapter or similar for programming it.
Maybe put male pins on each end instead.
Logged
Ontario, Canada
Offline Offline
Newbie
I love Arduino
View Profile
WWW
My initial idea was to use this board as a stand-alone with header pins or header female sockets. In other word, this board is not designed for using on a solderless breadboard. However, this board might be used on a breadboard if you have a multi-column breadboard.  My board will cover all the holes in a standard single column breadboard which has only 5 holes (0.1" apart) on each side.  Anyway, if you have a multi-column bread board and need to use it anyway, here is a way to use the reset and GND pins: attach pin-headers on each side except for the GND pin next to the RST (reset) pin.  There is another GND pin (6th from the bottom) on the right hand side of the board for the FTDI connection and you can use it for the reset function.
« Last Edit: February 19, 2011, 10:41:24 am by Jeonlab » Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
You don't need one, that's for building oscillators out of discrete CMOS logic gates where a DC feedback path is needed, the ATmega oscillator circuits are more sophisticated!
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
