Topic: Arduino MKRFOX1200 Problem!! Out of message sequence - expected 126, actual 122 (Read 1 time) previous topic - next topic
TodoElectronica21
Hi to everybody,
I have a problem that will me go crazy.
I am making probes with the MKRFOX 1200 (Arduino). All the probes are correct in the first day.
I send messages without problem. But the second day, the messages are not entering in the messages section. In the events section I can see that:
2018-01-24 18:38:57Out of message sequenceWARN1D19A0Invalid message sequence from Device #XXXXXX: expected 126, actual 122
My code it the same that the first day.
I need to put the "Disangage sequence number" buttom everytime that I turn off/on or change the code.
Does someone have the same problem?
Thanks in advance,
ecabanas
I had the same problem with one arduino, the rest 3 are working perfect
I'm getting crazy
Eduard
xnemp100
Hello, I have the same issue but at sequence 4095:
1CF5B5    Invalid message sequence from Device #1CF5B5: expected 1, actual 4095
Did you manage to resolve the issue ?
xnemp100
Sorry to hear. It looks to me as some generic HW related issue. Hopefully someone will be able to provide us with support. Otherwise I will have to RMA.
runningz
It's seems a conectivity problem.
Check the antenna wires... it's breaks easily, and have to be resolded.
NicolasHdez
Same problem with us.
It was working good on monday but since yesterday, i couldnt managed to make it work again. I think that the arduino works fine but there should be a problem with Sigfox. My DeviceId is valid because it shows the status: "Communication allowed but no keep-alive defined or no message received"
It fails just after the SigFox.EndPacket(). It returns a 0 code and cant see any message in the server.
Any idea?
