Loading...
Pages: [1]   Go Down
Author Topic: Servo over Cat5?  (Read 858 times)
Leeds, UK
Offline Offline
Newbie
View Profile
Hi, Just a quick one.
Would it be safe to power a smallish (I think) servo over Cat5 cable?
I hope that's not too vague.
The max length would be no more than five metres.
The servos are Acoms AS-17. I've tried to find a datasheet for the servos, but with no luck.
They would not be doing anything heavy, just panning and tilting a very small camera about the size of a webcam
I'm a newbie to all this so any help at all will be greatly received.
Thanks
Paul
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
You'd probably be okay. You're not talking amps of current, right?
Cat 5 cable is 26 guage wire?
You can look up current carrying capability of wire & voltage loss over distance online.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Cat5 is 24 guage, I am pretty sure that would handle the current for a servo ok.
At worst, you can double up the wires. Wikipedia says
Maximum current per conductor 0.577  A
So if you needed an amp, run 2 wires together.
Check these numbers also
http://en.wikipedia.org/wiki/Power_over_Ethernet
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
I forgot who mentioned this to me on the forum but there is more resistance on the crimped wire like RJ45 than other types of connection, maybe screw terminals, and definitely more resistance than soldered wires.
To reduce contact resistance, you can use multiple wires in the RJ45 cable to pass power and gnd. Say you only need to control one servo motor, then you can chain 3 wires of the RJ45 together to pass power, 3 wires together to pass gnd, and 2 together to pass sensor.
If you plan to run both sensor and power down the same wire, you should put some filter capacitors between the power and gnd, to prevent the power to couple with sensor. In a project I did last weekend, I had to put a 1uF cap for my sonic ranger to work on 12ft of phone cord.
http://liudr.wordpress.com/2011/02/12/arduino-parking-sensor/
Logged
Leeds, UK
Offline Offline
Newbie
View Profile
Thanks guys, really appreciate the help.
It seems like what i need to do should be fine.
Regarding the contact resistence issue, i will probably be soldering the connections.
I am not using leads and sockets, I just have a box of Cat5e that someone gave me.
With the eight cores i can do the following:
3 Cores together to supply common +6V
3 Cores together to supply common Ground
1 Core for Servo 1 Data
1 Core for Servo 2 Data
Lastly ( I promise), will the data line to the servo be ok over this distance, or is it a case of suck it and see?
I suppose as long as i'm not going to set anything on fire, I can just try it.
Thanks again
Paul
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
I've done several projects where I've used cat3 four conductor telephone wire between the servo controller and the servo, and had no issues.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Try it  see. At the worst, you give up one power/ground and keep the data lines as a twisted pair combination with signal/ground.
But since you're not sending high frequency signals here, you're probably gonna be okay.
Logged
Central MN, USA
Offline Offline
Faraday Member
View Profile
WWW
If you have the solid conductors in your cat-5 wires, you might be able to solder them ok. Most cat-5 wires are stranded and almost impossible to solder or strip the plastic without breaking them. Just give it a try first. You may end up deciding on using the connectors and jacks.
Logged
Leeds, UK
Offline Offline
Newbie
View Profile
Thanks again guys, much appreciated I can assure you.
Seems like I have plenty of options going forward.
Being on a budget isn't always fun but, at least you use up the things around you.
Thanks again
Paul
Logged
Monterrey, MX
Offline Offline
Newbie
stay thinking @ growing up
View Profile
WWW
hi,
accidentaly in the past, i was work with several tests over the use of cat5 cat5 shielded and cat6, using it for transmit usb signal, video signal, audio signal, little voltage currents and more.
and i was found than for like 5mts or more, the voltage input of the cable if is 12v, the output voltage will be more high, like 2~6v high.
why? because the cat cable is twisted and it prevents to loss signal, so it amplifies, for it reason have for more long distance vs a cable than isn't twisted!
so be carefull is your sistem is very sensitive to the voltage, i recommend you to check before the output voltage with a voltimeter.
regards! smiley-cool
Logged
Todo lo que no es posible imaginar, no es posible realizarlo.
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Are you saying that a passive cable amplifies a signal so you get more voltage out than you put in all because the wires are twisted together?
Logged
Central MN, USA
Offline Offline
Faraday Member
View Profile
WWW
Quote
Maybe his hand-held multimeter is rapidly losing battery power so reading keeps climbing  smiley-mr-green
Just joking. I don't think there will be increase of voltage from passing DC voltage down a twisted pair, why did Edison not think of that if the passive wire did amplify? He was beat by the problem of DC.
Logged
Monterrey, MX
Offline Offline
Newbie
View Profile
WWW
Well, sorry for the expression, would not refer to the literal sense, but the twisted cable acts as a kind of coiled but of course with much less spirals.
but if you don't believe me, you can search info in internet or make the test by yours, really i was surprise me when you try by accident
Logged
Pages: [1]   Go Up
Print
Jump to:
