Loading...
Pages: [1]   Go Down
Author Topic: Options for permanent soldered boards without etching?  (Read 455 times)
Lincoln, NE
Offline Offline
Full Member
Having lots of fun with Arduino. Thanks everyone!
View Profile
WWW
Etching my own custom board and drilling all the holes seems daunting, so I'm considering this:
http://www.mouser.com/ProductDetail/BusBoard-Prototype-Systems/BR1/?qs=dhMlBWDyGwd3hHrWdzxHJA%3d%3d
Could anyone point me to other (better/cheaper) protoboards? I'm in USA.  Thanks in advance!
Logged
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
Plain old stripboard (sometimes called Veroboard) is probably the cheapest option.  Widely available and cheap.
Buy yourself a track cutter while you're at it (also cheap, usually consisting of a small drill bit in a plastic handle)
« Last Edit: February 19, 2011, 11:57:51 am by pluggy » Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
How big of a board do you need?
I use velleman ecs1/2 for many projects, is a good size. 80mm x 100mm.
Velleman makes larger sizes also.  ECS1-H is 100mm x 160mm.
Both are "island of holes", one pad per hole.
I like velleman as the holes are very uniformly spaced - cheaper boards like Datek I have to be lower quality in that regard.
There are other options too, like boards with 2 & 3 pins connected together. Could be handy for solder adjacent parts together.
I usually have several chips that I am wirewrapping together and prefer the individual holes so I am not limited on placement.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Lincoln, NE
Offline Offline
Full Member
View Profile
WWW
Thanks for all the quick pointers.  Although searching for veroboard at digikey and mouser did not return meaningful results, I've ordered these:  http://futurlec.com/ProtoBoards.shtml
Quite inexpensive and available in many sizes and variations.
For future hunters, I've seen these boards called: protoboard, veroboard, euroboard, stripboard, busboard.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
I use simple proto boards and use 30 gauge wire-wrap wire for all the interconnections, except I cut to length and solder the wire. That wire lays nice and flat and doesn't steal too much vertical space. I do use large gauge wire for the main ground and power runs.
Lefty
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
The futurelec experimenters board looks great, lots of sizes to choose from. I'll have to order a couple & try them out next project.
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
Quote
Strangely, this isn't true in the United States.  Pad-per-hold is popular, and there are the proto-board-like PCBs that are sorta nice (http://www.radioshack.com/product/index.jsp?productId=2102846 ), but cheap stripboard never seems to have caught on.  Of course there are a bunch of mail-order dealers that fill the void...
Logged
Pages: [1]   Go Up
Print
Jump to:
