Loading...
Pages: [1]   Go Down
Author Topic: Multiple inclusion of custom library function.  (Read 1520 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I have written a file that takes in a number between -128 and 127 that corresponds with the output of a sensor.  -128 represents -1 and 127 represents 127/128.  The function is supposed to take an arcsine of this and return it.  I am computing the arcsine using a lookup table with -128 = -pi/2 and 127 = 127*pi/256 (slightly less than pi/2).
When I try to make this into a library function I get the following error:
magAcc.cpp.o: In function `arcsineLUTFunc(char)':
c:/arduino-0021/hardware/tools/avr/lib/gcc/../../avr/include/arcsineLUT.h:8: multiple definition of `arcsineLUTFunc(char)'
ADXL345\ADXL345.cpp.o:c:/arduino-0021/hardware/tools/avr/lib/gcc/../../avr/include/arcsineLUT.h:8: first defined here
c:/arduino-0021/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
magAcc.cpp.o:(.data.arcsineLUT1+0x0): multiple definition of `arcsineLUT1'
ADXL345\ADXL345.cpp.o:(.data.arcsineLUT1+0x0): first defined here
The file arcsineLUT.h is
Code:
#ifndef arcsineLUTFile
#define arcsineLUTFile
#include "WProgram.h"
char arcsineLUT1[256] = {/*lookup table numbers go here*/};
char arcsineLUTFunc(char index)
if(index > 127)
index = 127;
if(index < -128)
index = -128;
return arcsineLUT1[index - -128];
#endif
This file is not included anywhere else in my program.
The file that include it is (ADXL345.h)
Code:
#ifndef ADXL_h
#define ADXL_h
#include <Wire.h>
#include <arcsineLUT.h>
// Lots of #defines
class cADXL345
public:
//various different member functions and variables
private:
#endif // ADXL345_h
The corresponding cpp file is
Code:
#include "ADXL345.h"
//various different member functions that don't use arcsineLUT.h.
//The function that uses arcsineLUT.h stripped of irrelevant code.
void cADXL345::phiTheta()
theta = arcsineLUTFunc((char)(128*x)/xs);
phi    = arcsineLUTFunc((char)(128*y)/ys);
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I have solved the problem.
The array and function needed to go into a .cpp file and the function prototype in the .h file.
Logged
Pages: [1]   Go Up
Print
Jump to:
