Loading...
Pages: [1]   Go Down
Author Topic: 16x2 LCD Troubleshooting  (Read 1430 times)
Offline Offline
Newbie
View Profile
I spent a while looking through the forums for a solution to the issue I'm having with connecting a 16x2 LCD, but haven't come across anything quite like what I'm seeing. I followed this tutorial for wiring the connections: http://www.ladyada.net/learn/lcd/charlcd.html
I also made the necessary code changes to the LiquidCrystal HelloWorld sketch mentioned toward the end of the tutorial, namely the note about changing this:
Code:
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
to this:
Code:
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
Unfortunately, when I load and run the sketch this is what I see on the LCD:
As far as I can tell, everything is connected correctly. I even double-checked the header pin soldering for connectivity and shorts. The pattern shown on the LCD is at maximum contrast. This pattern was persistent before I connected the data lines (only backlight, pot, logic power connected) and goes away when the pot is turned down. I never got a single line of blocks mentioned in the tutorial at that step. I was thinking that there was something wrong with the LCD, but I tried a 2nd LCD to the same effect.
It would help if a 2nd (or 3rd, or n) set of eyes could look at this and give me some feedback. Thanks!
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
What's the exact part number of the LCD?
Logged
Offline Offline
Newbie
View Profile
GDM1602K
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Looks OK to me. Try measuring that you have +5V on the pins that should have it.
Logged
Offline Offline
Newbie
View Profile
Pins 2 and 15 have +5v.
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
The wiring and "code" look good to me too. Could be a bad display. Someone asked about this pattern in the past and if I recall correctly he/she sent it back for a replacement. Where was this display purchased?
Logged
Offline Offline
Newbie
View Profile
I got the display a few years ago from sparkfun.com. I figured it might be the display malfunctioning, so I ordered a 2nd one, different color, same model... similar result. I read that these LCDs are pretty robust, so I'm not so sure it's the display.
Logged
Central MN, USA
Offline Offline
Faraday Member
View Profile
WWW
I've purchased from several sources (not including sparkfun) and never had any problems of defective screens, even from surplus stores. I think the other guy with similar problem also bought from sparkfun. Maybe sparkfun got a bad batch.
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
Just out of curiosity, what does the display look like without connecting the six red wires to the Arduino ?  Normally you would get 'boxes' on the top row.
Don
Logged
Illinois
Offline Offline
Jr. Member
Arduino rocks
View Profile
Try the tutorial from Hacktronics.  It worked for me.
Make sure you have the LiquidCrystal.h library loaded
on your computer when you compile the sketch.
RWW
http://www.hacktronics.com/Tutorials/arduino-character-lcd-tutorial.html
Logged
Offline Offline
Newbie
View Profile
Thanks for everyone's replies! I meant to get back about this earlier. I ordered a new LCD from sparkfun and when I wired it up, everything worked as expected. What are the odds of 2 bad LCDs in a row?
Logged
Pages: [1]   Go Up
Print
Jump to:
