Author Topic: Arduino synthesiser  (Read 776 times)
I'm making the Auduino synthesiser ( http://code.google.com/p/tinkerit/wiki/Auduino ) and I cant get it working. I've triple checked all the wiring, no short circuits and all the connections are proper. I tried running it off Usb, and a 9v battery supply. The only thing I can think of is I'm missing a sound library because I couldn't open open the .PDE file with the Arduino program, but I found written copy somewhere, of just one code file. Please help.
« Last Edit: February 19, 2011, 09:52:34 pm by Technoi » Logged
Please help, anyone?
Austin, TX
CMiYC
You really haven't given much in terms of what is working and what isn't.  You give troubleshooting steps for hardware but only give detailed descriptions on software issues.
What is working?  What isn't working?  What is happening that you don't expect to happen?  (It helps to say:  "I expected this, but I got this..."
www.cmiyc.com - A guide to being an Enginerd
Well, the Arduino board is on and working, and I made sure the chip was working by making an LED blink just to test it. I also get the tiniest bit of static from it. But nothing else. I also cannot open the .PDE file for the Auduino with the arduino software, but I found what I believe to be it (Possibly a modified version).
Ok, so I got the Pot. on Analog pin 4 to work, but all the others do not effect the sound at all. The one I have now goes from a low to high pitch. Any suggestions?
Bump
UK
Gorm deficient
Code?
Per Arduino ad Astra
// Auduino, the Lo-Fi granular synthesiser
// by Peter Knight, Tinker.it http://tinker.it
// Help:      http://code.google.com/p/tinkerit/wiki/Auduino
// More help: http://groups.google.com/group/auduino
// Analog in 0: Grain 1 pitch
// Analog in 1: Grain 2 decay
// Analog in 2: Grain 1 decay
// Analog in 3: Grain 2 pitch
// Analog in 4: Grain repetition frequency
// Digital 3: Audio out (Digital 11 on ATmega8)
// Changelog:
// 19 Nov 2008: Added support for ATmega8 boards
// 21 Mar 2009: Added support for ATmega328 boards
// 7 Apr 2009: Fixed interrupt vector for ATmega328 boards
// 8 Apr 2009: Added support for ATmega1280 boards (Arduino Mega)
#include <avr/io.h>
#include <avr/interrupt.h>
uint16_t syncPhaseAcc;
uint16_t syncPhaseInc;
uint16_t grainPhaseAcc;
uint16_t grainPhaseInc;
uint16_t grainAmp;
uint8_t grainDecay;
uint16_t grain2PhaseAcc;
uint16_t grain2PhaseInc;
uint16_t grain2Amp;
uint8_t grain2Decay;
// Map Analogue channels
#define SYNC_CONTROL         (4)
#define GRAIN_FREQ_CONTROL   (0)
#define GRAIN_DECAY_CONTROL  (2)
#define GRAIN2_FREQ_CONTROL  (3)
#define GRAIN2_DECAY_CONTROL (1)
// Changing these will also requires rewriting audioOn()
#if defined(__AVR_ATmega8__)
// On old ATmega8 boards.
//    Output is on pin 11
#define LED_PIN       13
#define LED_PORT      PORTB
#define LED_BIT       5
#define PWM_PIN       11
#define PWM_VALUE     OCR2
#define PWM_INTERRUPT TIMER2_OVF_vect
#elif defined(__AVR_ATmega1280__)
// On the Arduino Mega
//    Output is on pin 3
#define LED_PIN       13
#define LED_BIT       7
#define PWM_PIN       3
#define PWM_VALUE     OCR3C
#define PWM_INTERRUPT TIMER3_OVF_vect
#else
// For modern ATmega168 and ATmega328 boards
#define PWM_PIN       3
#define PWM_VALUE     OCR2B
#define LED_PIN       13
#define LED_BIT       5
#endif
// Smooth logarithmic mapping
uint16_t antilogTable[] = {
  64830,64132,63441,62757,62081,61413,60751,60097,59449,58809,58176,57549,56929,56316,55709,55109,
  54515,53928,53347,52773,52204,51642,51085,50535,49991,49452,48920,48393,47871,47356,46846,46341,
  45842,45348,44859,44376,43898,43425,42958,42495,42037,41584,41136,40693,40255,39821,39392,38968,
  38548,38133,37722,37316,36914,36516,36123,35734,35349,34968,34591,34219,33850,33486,33125,32768
uint16_t mapPhaseInc(uint16_t input) {
  return (antilogTable[input & 0x3f]) >> (input >> 6);
// Stepped chromatic mapping
uint16_t midiTable[] = {
  17,18,19,20,22,23,24,26,27,29,31,32,34,36,38,41,43,46,48,51,54,58,61,65,69,73,
  77,82,86,92,97,103,109,115,122,129,137,145,154,163,173,183,194,206,218,231,
  244,259,274,291,308,326,346,366,388,411,435,461,489,518,549,581,616,652,691,
  732,776,822,871,923,978,1036,1097,1163,1232,1305,1383,1465,1552,1644,1742,
  1845,1955,2071,2195,2325,2463,2610,2765,2930,3104,3288,3484,3691,3910,4143,
  4389,4650,4927,5220,5530,5859,6207,6577,6968,7382,7821,8286,8779,9301,9854,
  10440,11060,11718,12415,13153,13935,14764,15642,16572,17557,18601,19708,20879,
  22121,23436,24830,26306
uint16_t mapMidi(uint16_t input) {
  return (midiTable[(1023-input) >> 3]);
// Stepped Pentatonic mapping
uint16_t pentatonicTable[54] = {
  0,19,22,26,29,32,38,43,51,58,65,77,86,103,115,129,154,173,206,231,259,308,346,
  411,461,518,616,691,822,923,1036,1232,1383,1644,1845,2071,2463,2765,3288,
  3691,4143,4927,5530,6577,7382,8286,9854,11060,13153,14764,16572,19708,22121,26306
uint16_t mapPentatonic(uint16_t input) {
  uint8_t value = (1023-input) / (1024/53);
  return (pentatonicTable[value]);
// midi control variables
int midi_note = 0;
int get_note = 0;
int key_pressed = 0;
void audioOn() {
  // ATmega8 has different registers
  TCCR2 = _BV(WGM20) | _BV(COM21) | _BV(CS20);
  TIMSK = _BV(TOIE2);
  TCCR3A = _BV(COM3C1) | _BV(WGM30);
  TCCR3B = _BV(CS30);
  TIMSK3 = _BV(TOIE3);
#else
  // Set up PWM to 31.25kHz, phase accurate
  TCCR2A = _BV(COM2B1) | _BV(WGM20);
  TCCR2B = _BV(CS20);
  TIMSK2 = _BV(TOIE2);
#endif
  pinMode(PWM_PIN,OUTPUT);
  audioOn();
  pinMode(LED_PIN,OUTPUT);
  Serial.begin(38400);  // added for midi i/o
  // The loop is pretty simple - it just updates the parameters for the oscillators.
  // Avoid using any functions that make extensive use of interrupts, or turn interrupts off.
  // They will cause clicks and poops in the audio.
  // Smooth frequency mapping
  //syncPhaseInc = mapPhaseInc(analogRead(SYNC_CONTROL)) / 4;
  // Stepped mapping to MIDI notes: C, Db, D, Eb, E, F...
  // syncPhaseInc = mapMidi(analogRead(SYNC_CONTROL));
  // Stepped pentatonic mapping: D, E, G, A, B
  //syncPhaseInc = mapPentatonic(analogRead(SYNC_CONTROL));
  // could add switch here to choose between midiIn() and the twisty-pot pitch control
  midiIn();
  grainPhaseInc  = mapPhaseInc(analogRead(GRAIN_FREQ_CONTROL)) / 2;
  grainDecay     = analogRead(GRAIN_DECAY_CONTROL) / 8;
  grain2PhaseInc = mapPhaseInc(analogRead(GRAIN2_FREQ_CONTROL)) / 2;
  grain2Decay    = analogRead(GRAIN2_DECAY_CONTROL) / 4;
SIGNAL(PWM_INTERRUPT)
  uint8_t value;
  uint16_t output;
  syncPhaseAcc += syncPhaseInc;
  if (syncPhaseAcc < syncPhaseInc) {
    // Time to start the next grain
    grainPhaseAcc = 0;
    grainAmp = 0x7fff;
    grain2PhaseAcc = 0;
    grain2Amp = 0x7fff;
    LED_PORT ^= 1 << LED_BIT; // Faster than using digitalWrite
  // Increment the phase of the grain oscillators
  grainPhaseAcc += grainPhaseInc;
  grain2PhaseAcc += grain2PhaseInc;
  // Convert phase into a triangle wave
  value = (grainPhaseAcc >> 7) & 0xff;
  if (grainPhaseAcc & 0x8000) value = ~value;
  // Multiply by current grain amplitude to get sample
  output = value * (grainAmp >> 8);
  // Repeat for second grain
  value = (grain2PhaseAcc >> 7) & 0xff;
  if (grain2PhaseAcc & 0x8000) value = ~value;
  output += value * (grain2Amp >> 8);
  // Make the grain amplitudes decay by a factor every sample (exponential decay)
  grainAmp -= (grainAmp >> 8) * grainDecay;
  grain2Amp -= (grain2Amp >> 8) * grain2Decay;
  // Scale output to the available range, clipping if necessary
  output >>= 9;
  if (output > 255) output = 255;
  // Output to PWM (this is faster than using analogWrite)
  PWM_VALUE = output;
// auduino simple midi input routine - should work with midi shields,
// definately works with the serial-midi software interface downloadable
// from http://www.spikenzielabs.com/SpikenzieLabs/Serial_MIDI.html
// allows midi without extra cabling (other than usual USB).
// Tested on freeduino board, don't have the others to test with.
// note: if you use the serial<>midi converter above, remember to select
// 38400 bps when you set it going.
// by Tel Bonic
void midiIn()
  // read a byte from the serial/midi input
  byte incByte = 0;
  if (Serial.available() > 0) {
    // read an incoming byte out of the stack
    incByte = Serial.read();
    // un-comment to echo midi data back out if required
    // Serial.print(incByte);
    // start playing note now we have the byte
    if (get_note == 1) {
      midi_note = incByte;
      get_note = 0;
      syncPhaseInc = midiTable[midi_note];
    // make sure no sounds if nothing playing
    if (key_pressed == 0) {
      syncPhaseInc = 0;
    // Check whats playing
    switch (incByte) {
      // key pressed on channel 1 - look up a midi table via google if planning to expand
      // Control byte is 144 decimal if "start note on channel 0" is received.
    case 144:
      key_pressed = 1;
      get_note = 1;
      break;
      // key up on channel 1
    case 128:
      key_pressed = 0;
      break;
Here you go.
Bump
