Topic: Optiboot for Atmega8 needed. (Read 9687 times) previous topic - next topic
alparent
Feb 20, 2011, 07:17 am Last Edit: Feb 20, 2011, 07:19 am by alparent Reason: 1
I need help getting the optiboot_ATmega8.hex file.
I've downloaded the latest optiboot v3 zip file ....installed everything......open Arduino IDE ...... I see a lot of OPTIBOOT boards but no Atmega8?
I guess I need to do something? The optiboot site says it's supported.
Did some research and found some files needed updating. Did that.
Now I see an entry with optiboot atmega8 in the IDE but get an error message that the optiboot_atmega8.hex dose not exist?
Did more research.....I think I need to MAKE it.
Tried to make it and I keep getting errors. I'm on WinXP SP3.
I'm not a programmer so I'm kinda lost  :smiley-red:
Can someone make me a optiboot_atmega8.hex please.
Do I also need a .LST file?
And is that all I'm missing to have a atmega8 optiboot?
Thanks again!
westfw
#1
Feb 20, 2011, 08:30 am Last Edit: Feb 21, 2011, 04:03 am by westfw Reason: 1
Quote
No, you also need to know the correct fuses for mega8:  HFUSE = CC, LFUSE = BF
optiboot_atmega8.hex:
Code: [Select]
:101E00008FE594E09EBF8DBF112484B714BE81FF7F
:101E1000C7D085E08EBD82E08BB988E18AB986E8BB
:101E200080BD80E189B98EE0B7D0BD9A96E020E30D
:101E30003CEF54E040E23DBD2CBD58BF08B602FE69
:101E4000FDCF88B3842788BBA8959150A1F799242A
:101E50009394A5E0AA2EF1E1BF2E99D0813421F40C
:101E600081E0A9D083E01FC0823411F484E103C073
:101E7000853419F485E09FD083C0853579F487D007
:101E8000E82EFF2484D0082F10E0102F00270E2901
:101E90001F29000F111F89D0680172C0863529F4EF
:101EA00084E089D080E06FD06BC0843609F042C0F6
:101EB0006ED06DD0082F6BD080E0C81688E1D806B0
:101EC00020F483E0F60187BFE895C0E0D1E05FD061
:101ED00089930C17E1F7F0E0CF16F8E1DF0620F068
:101EE00083E0F60187BFE89560D007B600FCFDCF20
:101EF000A601A0E0B1E02C9130E011968C911197F1
:101F000090E0982F8827822B932B1296FA010C01D0
:101F100097BEE89511244E5F5F4FF1E0A034BF07F4
:101F200051F7F601A7BEE89507B600FCFDCFB7BE96
:101F3000E89526C08437B1F42AD029D0F82E27D0CE
:101F400034D0F601EF2C8F010F5F1F4F84911BD00F
:101F5000EA94F801C1F70894C11CD11CFA94CF0C83
:101F6000D11C0EC0853739F420D08EE10CD083E926
:101F70000AD087E098CF813511F488E00DD015D0D4
:101F800080E101D06ACF5D9BFECF8CB90895A89502
:101F90005F9BFECF8CB1089598E191BD81BD0895FE
:101FA00080E0FADFEE27FF270994F1DF803209F0A5
:101FB000F7DF84E1E8CF1F93182FE9DF1150E9F72D
:061FC000F4DF1F910895FB
:0400000300001E00DB
:00000001FF
(added 2/20)
Once you have the optiboot loaded on your mega8, don't forget that you'll need to edit boards.txt so that the arduino IDE knows how to talk to it (speed and max sketch size are different than the normal bootloader.)
Code: [Select]
opti8.name=Arduino Optiboot8
opti8.upload.protocol=stk500
opti8.upload.maximum_size=7680
opti8.upload.speed=115200
opti8.bootloader.low_fuses=0xbf
opti8.bootloader.high_fuses=0xdc
opti8.bootloader.path=optiboot
opti8.bootloader.file=optiboot_mega8.hex
opti8.bootloader.unlock_bits=0x3F
opti8.bootloader.lock_bits=0x0F
opti8.build.mcu=atmega8
opti8.build.f_cpu=16000000L
opti8.build.core=arduino
alparent
Thank a lot for that code.
Can you explain how you created that file? Just to educate me.
westfw
It will depend on how much of a SW development environment you already have installed on your computer, and the type of computer.  On my Mac, I already have the Mac developer tools installed, so I have utilities like "make" already available, which makes things easier.  It OUGHT to be possible to build optiboot using only the files installed as part of the Arduino install (which includes make, the compiler, and a bunch of other tools, buried in that 100M+ of install), but that is (paradoxically?) more difficult...
In general:
1) Download the latest optiboot source from the mercurial repository (oh, you'll need mercurial as well!)  Note that this is well past the latest .zip file (for example, it includes the atmega8 modifications.)
2) patch optiboot.c as needed or desired for assorted problems (see the google code "issue" list.)
3) patch the optiboot makefile to point most of the tools (compiler, avrdude) at the versions in the arduino distribution.
4) in a shell window, do "make atmega8"
alparent
OK thanks for the info.
I've uploaded the optiboot to my atmega8 with no issues.
But when I try to upload a sketch I get the following errors:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
FYI the atmega8  is on a breadboard with a 16mhz resonator.
I did the same this I did when the atmaga8 had the standard bootloader (non-optiboot) and that worked fine.
Now with the optiboot on the atmega8 I get those errors......the sketch I'm trying to load is blink (if that make any diffferance?)
Thanks again for your time and help.
westfw
Did you change the "boards.txt" file to include a "board" for the mega8 running optiboot?
The upload speed is different from  the normal mega8 boards (the the max sketch size changes.)
I have:
Code: [Select]
(going back and editing my original reply to include this info.)
alparent
Yes I did.
I'm using an ATMEGA8-16AU 32pin SMD. If that make any difference. (For the fuses or something?)
Also using this setup: "Uploading Using an Arduino Board" section of this page http://arduino.cc/en/Tutorial/ArduinoToBreadboard
westfw
Well,  I re-confirmed that it seems to work here, putting the mega8 into a duemilanove board.
I am having a hell of a time trying to get it to work in my SSS Arduino (with manual reset), however.
I'm going to check the timeouts and see if they are specified differently on mega8 vs mega328...
alparent
I see on another post that you add issues with atmega8 and resonators...I'm using a resonator.
Also do I need that .lst file?
alparent
IT WORKS!!!!
The problem was with the reset.
First I followed this example "Uploading Using an Arduino Board" section of this page http://arduino.cc/en/Tutorial/ArduinoToBreadboard
But after reading this http://www.instructables.com/id/Arduino-on-all-sorts-of-Atmels/step4/Program-MCUs-with-bootloader/
I tried it and added a wire between pin 1 of the onboard socket (wich has the MCU removed) and the reset pin of my atmega8 and it worked!
alparent
Thanks a million westfw.
I just programmed 4 32 pins atmega8 with blink to test them out and work just perfect.
Optiboot works great and it's fast!
hunyango
Would it be possible to have a atmega8 optiboot compiled for 8MHz?
alparent
BUMP  :~
I don't like to bump stuff......but I would also really like to have this!
Coding Badly
While I lack the experience to help you directly I can tell you that everything you need to build a bootloader is already on your computer.
westfw
Quote
The version of optiboot distributed with Arduino does not yet include support for atmega8.
Here's hex code for an 8MHz atmega8.  Not tested this time; YMMV, and watch your fuse settings...
I'm calling this version 4.2 (calling the latest Arduino version, 4.0 being the source from mercurial, and .2 being two sets of significant edits by me.)  If you look closely you'll see the number 0402 at the end of flash space.
Code: [Select]
:10000000112484B714BE81FFD3D085E08093810092
:1000100082E08093C00088E18093C10086E08093F5
:10002000C20080E18093C4008EE0BCD0259A86E0B7
:1000300020E33CEF91E0309385002093840096BB51
:10004000B09BFECF1D9AA8958150A9F7992493944F
:10005000A5E0AA2EF1E1BF2E9DD0813421F481E0EC
:10006000B2D083E01FC0823411F484E103C0853430
:1000700019F485E0A8D083C0853579F48BD0E82EBB
:10008000FF2488D0082F10E0102F00270E291F29E9
:10009000000F111F92D0680172C0863529F484E0E8
:1000A00092D080E06FD06BC0843609F042C072D02D
:1000B00071D0082F6FD080E0C81688E3D80620F4EE
:1000C00083E0F60187BFE895C0E0D1E063D0899373
:1000D0000C17E1F7F0E0CF16F8E3DF0620F083E03D
:1000E000F60187BFE89569D007B600FCFDCFA601F1
:1000F000A0E0B1E02C9130E011968C91119790E046
:10010000982F8827822B932B1296FA010C0197BE09
:10011000E89511244E5F5F4FF1E0A038BF0751F71B
:10012000F601A7BEE89507B600FCFDCFB7BEE8957F
:1001300026C08437B1F42ED02DD0F82E2BD03DD050
:10014000F601EF2C8F010F5F1F4F84911BD0EA94B3
:10015000F801C1F70894C11CD11CFA94CF0CD11C32
:100160000EC0853739F429D08EE10CD084E90AD04D
:1001700086E098CF813511F488E014D01ED080E15C
:1001800001D06ACF982F8091C00085FFFCCF90935B
:10019000C6000895A8958091C00087FFFCCF80918C
:1001A000C6000895E0E6F0E098E19083808308952A
:1001B00080E0F8DFEE27FF270994ECDF803209F0BA
:1001C000F7DF84E1DFCF1F93182FE4DF1150E9F749
:0601D000F4DF1F91089509
:021FFE000204DB
:00000001FF
