Loading...
Pages: [1]   Go Down
Author Topic: Control camera shutter with arduino  (Read 1923 times)
Offline Offline
Full Member
View Profile
I was looking at some tutorials for making some time lapse type of projects with the arduino.  But you most likely always need an expensive camera that has a jack to plug in our arduino board with the shutter data.
For those of us with simple point and click cameras don't fret! I have a new idea that would work very well if built right so here it is.
The basis of this project relies on a servo! First you make a stand and harness system for your servo and camera. Basically you want the servo to have a little rod on one of it's rotors. Then you program the servo to turn a certain number of degrees which in turn pushes down the little rod and clicks the shutter. And after that you program it to come back up the same number of degrees and delay it for a certain amount of time.
So there you go! I am hoping to try this out some time and tell me what you think of the idea! or maybe even easier ways of doing this task!
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Don't see why it shouldn't work, if it can't be done electrical do it mechanical!
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
0
Offline Offline
Faraday Member
20 LEDs are enough
View Profile
WWW
Easier: do not invent it yourself, always search the net:
If the camera is a cheap canon camera have a look at CHDK http://chdk.wikia.com/wiki/CHDK. Otherwise have a look here http://www.instructables.com/id/Time-lapse-add-on-to-a-Rollei-digicam/. And if you do not dare to open it, then finally look her: http://www.instructables.com/id/electromechanical-time-lapse-trigger/.
Udo
Logged
Check out my experiments http://blog.blinkenlight.net
Louisville, CO
Offline Offline
Full Member
Arduino rocks
View Profile
WWW
I recently posted code which uses generic PTP commands to trigger digital camera via USB -> http://www.circuitsathome.com/camera-control/generic-ptp-control-of-digital-cameras It should work with any Nikon including cheap S-series ones. You'll need one of my USB host shields for this to work.
Logged
/felis
Pages: [1]   Go Up
Print
Jump to:
