Topic: Not receiving bluetooth data in time (MIT Appinventor) (Read 391 times) previous topic - next topic
Deranda
Hello,
I'm working on an automated indoor garden which can be controlloed through a mobilephone app via bluetooth. Therfore I use an arduino pro micro with the HC-05 Bluetooth module and the MIT Appinventor.
I start the app, connect to the arduino and everything seems to be fine. But wenn I want to check the temperature inscide the greenhouse, by clicking my Sync Button, the App does not display the current temperature. Instead it displays the temperature from the last synchronization.
So the arduino works fine I think. -> It sends the data, if the incoming command provides it.
The blocks from the Appinventor are pictured below.
Would be great if someone can help me with that.
best regards!
Robin2
Image from Original Post so we don't have to download it. See this  Simple Image Guide
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Robin2
This is not the place to get help with AppInventor.
If it would help for someone to review your Arduino code then post your program.
...R
Deranda
Here is the source code. There is some other code in the setup but it does not affect the serial communication.
Code: [Select]
void setup(){
  Serial.begin(9600);                               // Baudrate of the Bluetoothmodule
  if(Serial.available() > 0){                      // wait until there is data to receive
    recieveByte = Serial.read();                // Einlesen der Daten
  if(receiveByte == 108) {                      // received data: l (ASCII: 108)
    lux = lichtSensor.GetLightIntensity();  // measure the brightness
    Serial.print(lux);                               // send back data
    lux = 0;
    recieveByte = 0;
Robin2
You need to post the complete program. If the problem was where you think it is you would have found it already.
If you use SoftwareSerial to create a separate serial port for your Bluetooth device you can use Serial for debugging messages.
...R
Deranda
Full code
Code: [Select]
#include <SPI.h>
#include <Wire.h>
#include <BMP180.h>
#include <DHT.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <BH1750FVI.h>
#define dht_bodenPin 4
#define dht_luftPin 5
#define relais1 6
#define relais2 7
#define relais3 8
#define relais4 9
#define mosfet_fan 11;
#define mosfet_led 12;
BMP180 barometer;                           //Barometer BMP180
Adafruit_SSD1306 display(4);                //Display
DHT dht_Luft(DHT22, dht_luftPin);           //DHT22 Luftsensor an Pin D5
DHT dht_Boden(DHT22, dht_bodenPin);         //DHT22 Bodensensor an Pin D4
BH1750FVI lichtSensor;                      //Lichtesensorobjekt
unsigned long prevMillis;
unsigned long curMillis;
unsigned long delayMillis;
long pressure;            // Druckmesswert
long lux;               // Helligkeitsmesswert
float temperature;        // Temperaturmesswert
float humidity;           // Luftfeuchtemesswert
int recieveByte;          // Empfangsdaten der seriellen Schnittstelle
   * ***Serielle Schnittstellen und I2C Bus***
  Wire.begin(0x77);                           //Starte I²C des Barometers (0x77)
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  //Starte I²C des Displays (0x3C)
  dht_Luft.begin();                           //Starte Luftsensor
  dht_Boden.begin();                          //Starte Bodensensor
  lichtSensor.begin();                        //Starte Lichtsensor
  lichtSensor.SetAddress(0x23);               //I²C Adresse des Sensors
   * ***Sensoren Setup***
  //Barometer Setup()
  barometer = BMP180();
  if(barometer.EnsureConnected()){
    barometer.SoftReset();
    barometer.Initialize();
  //Display Setup()
  display.setTextColor(WHITE);
  display.clearDisplay();
  //Lichtsensor Setup();
  lichtSensor.SetMode(Continuous_H_resolution_Mode);
   * ***Pinmode Setup***
  pinMode(relais1, OUTPUT);
  pinMode(relais2, OUTPUT);
  pinMode(relais3, OUTPUT);
  pinMode(relais4, OUTPUT);
   * ***Variablen Setup***
  recieveByte = 0;
  lux         = 0;
  pressure    = 0;
  temperature = 0;
  humidity    = 0;
  if(Serial.available() > 0){               // Überprüfen ob Puffer gefüllt ist
  if(recieveByte == 104) {                  // Emfpangsdaten: h (ASCII: 104)
    lux = lichtSensor.GetLightIntensity();  // Helligkeit messen
    Serial.println(lux);                    // Daten zurück senden
    lux = 0;
    recieveByte = 0;
long getPressure(){
  pressure = 0;
  if(barometer.IsConnected){
    for(int i = 0; i < 10; i++){
      pressure += barometer.GetPressure();
    pressure /= 10;
  else{
    pressure = 0;
  return pressure;
float getTemperature(){
  return dht_Luft.readTemperature();
float getHumidity(){
  return dht_Luft.readHumidity();
uint16_t getLightIntensity(){
  return lichtSensor.GetLightIntensity();
void displayText(){
  display.setTextSize(1);
  display.setCursor(1,0);
  display.println("1st Row");
  display.print("2nd Row");
Robin2
Thank you. However I am still confused.
In your Original Post you say "the App does not display the current temperature. Instead it displays the temperature from the last synchronization."
But your code only seems to be sending a light intensity value.
As I mentioned in Reply #4, change your program around so that that the HC05 is connected to another pair of pins and uses SoftwareSerial so you can use Serial for debug messages to the Arduino Serial Monitor. At the moment you have no means to know what the Arduino is actually doing.
...R
