Topic: Unable to upload sketch (Read 567 times) previous topic - next topic
santoshiva13
I am new to arduino, i am trying to upload a sketch and getting following error.
open nul: the system cannot find the file specified.
error compiling for board arduino/genuino uno.
OS: Windows 10
Arduino Ide : 1.8.5
Please help
ballscrewbob
I think you may want to read this post first and add some extra information.
Also make sure you are not using a USB 3.0 port and that you have selected the correct COM port as listed in windows device manager for the board (you failed to mention type).
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
joeldennis
#2
Feb 13, 2018, 05:37 pm Last Edit: Feb 13, 2018, 05:46 pm by joeldennis
I have some problem while uploading arduinoisp to new atmega328P-PU it shows invalid library and bootloader while click this message shows...
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
Error while burning bootloader.
Englishscone
Hello!,
If you want, try out this post, Error conpiling to Arduino Uno-SOLVED!
Kev9991
Hi... I am also new to Arduino and I can't seem to upload a sketch. Any help would be greatly appreciated.
Arduino: 1.6.11 (Windows 8.1), Board: "IntelĀ® Edison"
Sketch uses 76,331 bytes (0%) of program storage space. Maximum is 10,000,000 bytes.
C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin/bash.exe --verbose --noprofile C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\Kevin\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp/Blink.ino.elf COM5
#!/bin/sh
# clupload script to invoke lsz
# Copyright (C) 2014 Intel Corporation
# This library is free software; you can redistribute it and/or
# modify it under the terms of the GNU Lesser General Public
# License as published by the Free Software Foundation; either
# version 2.1 of the License, or (at your option) any later version.
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
# Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with this library; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
echo "starting download script"
echo "Args to shell:" $*
# ARG 1: Path to lsz executable.
# ARG 2: Elf File to download
# ARG 3: COM port to use.
#path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
#COM ports are not always setup to be addressed via COM for redirect.
#/dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadEdison" > $tty_port_id
Args to shell: C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\Kevin\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp/Blink.ino.elf COM5
COM PORT 5
Converted COM Port COM5 to tty port /dev/ttyS4
C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 42: /dev/ttyS4: Permission denied
Deleting existing sketch on target
#Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 46: /dev/ttyS4: Permission denied
# Execute the target download command
#Download the file.
host_file_name=$2
"$fixed_path/lsz.exe" --escape --binary --overwrite $host_file_name <> $tty_port_id 1>&0
C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 51: /dev/ttyS4: Permission denied
#mv the downloaded file to /sketch/sketch.elf
target_download_name="${host_file_name##*/}"
Moving downloaded file to /sketch/sketch.elf on target
echo "Moving downloaded file to /sketch/sketch.elf on target"
"$fixed_path/lsz.exe" --escape -c "mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf" <> $tty_port_id 1>&0
C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 56: /dev/ttyS4: Permission denied
An error occurred while uploading the sketch
option enabled in File -> Preferences.
pert
Are you certain your Edison board is on COM5?
Try this:
  • With the Arduino board unplugged from the USB open the Tools > Port menu and note the listed ports. If the Port menu is gray and disabled then that means there are no ports available.
  • Close the Tools > Port menu.
  • Plug in the USB cable on the Arduino board
  • Wait a little while for the Arduino board to connect
  • Open Tools > Port, the new port on the list is your Arduino board. In some cases it will have the name of the board next to the port name but this doesn't happen with all boards. If the Port menu is gray and disabled then that means your Arduino board didn't install correctly. You may need to install a driver.
  • Select your Arduino's port from the menu.
If the COM5 port is correct, try restarting your computer. Sometimes COM ports can get stuck and cause this sort of problem.
