Topic: custom PCB(ATMEGA328P/Arduino pro mini ) run with coin cell issue (Read 549 times) previous topic - next topic
pratik24192
Hello,
I'm working on one of the project and its board MCU is ATMEGA328P.
When I'm run on coin cell with custom PCB then MCU will be restart again n again.
When I'm run on Li-ion battery its code and MCU working very well.
So, please tell me the issue and suggest me the test case for overcome this issue.
Thank you.
Regards,
PRATIK
spycatcher2k
Quote
As long as you don't pull more then around 25mA, then this should work if you disable BOD. But as you have NOT posted a schematic, then this is just a guess.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
