Topic: Controlling 3-wire PWM fan speed (Read 2419 times) previous topic - next topic
pnolan
Hello all,
I'm new to using arduino and new to the forums and I was hoping I could get some help on my project.  I am trying to build a simple remote control hovercraft and control the fans with an arduino uno.  My aim is to have both the lift and propulsion fan speeds controllable through an RC transmitter.  I really have no idea where to even start for the code, though.  I want to be able to push a stick on the transmitter forward and have the fan speed increase, push it back and the fan speed decrease.
I am using this fan: http://www.thermaltakeusa.com/Product.aspx?C=1164&ID=1722#Tab1
Any advice you could give would be much appreciated, and any code would help me out a lot.
pnolan
I'm really stuck here.  I know the code should be fairly simple--just simply increase or decrease fan speed when the stick is moved.  Please, any advice will help
Magician
Have a look at :
http://www.codeproject.com/KB/system/RC_Joystick_Tx.aspx
Project more complicated than yours, but remove unnecessary parts
shouldn't be a problem
pnolan
Thank you, magician.  That helps a little bit.  However, it seems almost too much for what I am trying to do.  I want to just be able to read in values sent to the arduino from a receiver that is paired with the transmitter, scale them, and then control the fan speed based on those scaled values.
pnolan
If I just wanted to modify the PWM of the fans, how would I do that?  Like, for instance, if I could take in a "desired" fan speed from the transmitter, how can I output what I want the fan to do corresponding to what value I get from the transmitter?
Magician
Check on a link:
http://en.wikipedia.org/wiki/Control_theory
It will give you an idea, in which direction to dig your local library and google. :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
