Topic: TLC5940 LED fade coding not full brightness VS Tlc.set(1, 4095); (Read 280 times) previous topic - next topic
toxsickcity
I am having troubles making a 2 Colour LED fade at full brigtness..
i am thinking its something to do with arduino having 1023 vs TLC having 4095 pwm levels?!
I have a arduino with ntc 10k thermal sensor and it controls lighting...
I had added some code to compare the real full brightness and appear to be half.
I am in the process of converting my code from MOSFET/Arduino to TLC.
at the moment the setColorVGA / redVGA, blueVGA are the parts of code in question.
cheers.
Code: [Select]
  if (tempVGA < COLDTEMP) tempVGA = COLDTEMP;
  if (tempVGA > HOTTEMP) tempVGA = HOTTEMP;
Code: [Select]
  redVGA = map(tempVGA, COLDTEMP, HOTTEMP, 255, 0);  // reverse 0, 255 for resistance use
  blueVGA = map(tempVGA, COLDTEMP, HOTTEMP, 0, 255);
Code: [Select]
void setColorVGA(int redVGA, int green, int blueVGA) {
#ifdef COMMON_ANODE
  redVGA = 255 - redVGA;
  blueVGA = 255 - blueVGA;
#endif
//  analogWrite(ledVGAR, redVGA);
//  analogWrite(ledVGAB, blueVGA);
Tlc.set(1, redVGA);
Tlc.update();//actually executes the pin states programmed above
Tlc.set(2, blueVGA);
Qdeathstar
Hi, you should give us the smallest sketch that reproduces the problem.
Depending on the library you are using for the TLC5940, this looks wrong:
Tlc.set(1, redVGA);
redVGA should possibly be mapped to a value between 0 and 4095
https://www.arduino.cc/reference/en/language/functions/math/map/
TLCredVGA = map(redVGA, 0, 255, 0, 4095);
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
Grumpy_Mike
Quote
Well yes but the Arduino's PWM has only 256 levels not 1023, you are mixing that up with the analogue read range.
