Topic: Sign language with flex sensors (Read 1 time) previous topic - next topic
shrikant_arts
hello,
i'm working on a project for deaf and dumb people.
i'm having flex sensor which is connected to arduino and a lcd display 16x2 connected to arduino.  too
when i bend the flex a flex sensor which is gven as an input A0 to the arduino ,  a corresponding message should be displayed on the lcd.
for example : if a flex sensor is bent,  a message saying  " food "  should display on the lcd.
i'm having difficulty in creating a code for that.can anyone help me out with this? please.
6v6gt
Post a link to the flex sensor you are using for this project.
Are you intending that the arduino can display multiple messages depending on the output of the flex sensor ?
shrikant_arts
no, a single flex sensor on bending should display a text on lcd display .
one value for single flex sensor
6v6gt
In principle, you incorporate each flex sensor in a voltage divider across the power rails with the centre tap connected to an analog pin.
In your program, you poll each analog pin in turn and watch for a change in voltage level since the last poll.
If there is a change, you write a message to the display.
If you use an Arduino Nano, you get 8 analog pins. If you use a Uno you get 6. If these are not enough, you can get an external ADC chip.
shrikant_arts
yes see what actualyy, flex sensors having two pins.
one i have given as an input and second to the gnd and side by side an lcd connection is also attached with the arduino.
i bit confused with this totallt.
i have written a code but it doesnt work can u helpme out.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12,11,5,4,3,2);
int flexPin1 = A0;
int value1;
lcd.begin(16,2);
    lcd.setCursor(0,0);
    lcd.print("Sign Language");
  delay(200);
 value1 = analogRead(flexPin1);
 Serial.print(value1);
   value1 = map(value1, 760, 950, 0, 255);
     if(value1 > 80)
    Serial.print("Food");
    lcd.clear();
      digitalWrite(6, HIGH);
    lcd.print("Foods");
TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
It is important we see how you have wired your flex sensors.
Have you got the LCD display working?
Thanks.. Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
6v6gt
shrikant_arts
yes, lcd connecctions are quite working well.
my flex sensor one pin is connected with gnd of arduino and another is as a input to the arduino
shrikant_arts
6v6gt
OP's picture:
The wiring diagram is (probably) incorrect. I've tried to ask 2 times what sensor is being used.
This is the correct wiring diagram for a Sparkfun sensor.
shrikant_arts
yes i told you its a flex sensor 2.2 inches one.
yes i have connected the same way the link which provided the connections.
the circuit i drew is wrong. sry.
ChrisTenone
#11
Feb 16, 2018, 12:40 pm Last Edit: Feb 16, 2018, 01:07 pm by ChrisTenone
It seems like a doable project, but the programming will be complex.
The sketch you posted (without [code]tags [/code]!!) would seem to work for a small number of words formed on a single finger. The range from 760 to 950 will limit you to ten or so unique positions (use an opamp to stretch this range to the full 10 bits Arduino can handle.) Some "fuzzy logic" should help compensate for slight variations. Best would be a sensor for every articulated joint, at least a dozen. Use arrays to translate between words and series of flex sensor values.
Atmosphere carries combustion vapors to places where they will do good instead of harm - Mike Faraday's 'History of a Candle': https://www.youtube.com/watch?v=6W0MHZ4jb4A
Whoops ::)
6v6gt
Look very carefully at the link for the wiring diagram of the Sparkfun Flex sensor.
There is a 47K Ohm resistor. between ground and the analog pin. Look also at what part of the sensor is connected to 5 Volt. The sensor together with the resistor form a voltage divider.
shrikant_arts
connecions are pretty good.code isn't working
6v6gt
You've claimed that the LCD code works so my suggestion is to create a new sketch based purely on the Sparkfun code example and get that working. After that, join the your LCD code to the working example.
