Loading...
Pages: [1]   Go Down
Author Topic: LED Clock Pinouts?  (Read 1239 times)
Offline Offline
Newbie
View Profile
I took apart a Mr. Coffee coffeemaker and took this LED clock out of it.
I have absolutely no clue where to plug stuff into on it.
I searched all over the internet but could not find anything...part of the problem is I don't know what you would call it exactly (LED clock, LED number board, 3 digit board, etc)
I included pictures and labeled the pins myself so they may be backwards to other people, I don't know.
If anyone knows where power and ground would go it would be greatly appreciated. I can figure out the rest of the pins myself.
OR if anyone can give me a link to someone who's already posted this or at least tell me what this would be called specifically so I could poke around the internet some more.
thanks for helping,
blakjakd
Logged
ottawa, canada
Offline Offline
God Member
Arduino rocks
View Profile
I would call it a 3 1/2 digit LED display module.  nice job unsoldering it by the way.
chances are each of the digits has a separate ground pin and all the digits share segment pins - look at the display in the top of the image below:
You can safely poke away with 5 volts through a 1k resistor just trying different combinations til you figure it out.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Do a google search for this
liteon 3 1/2 digit display
You are looking for datasheets like this
http://optoelectronics.liteon.com/en-us/api/DwonloadFileHandler.ashx?txtSpecNo=DS-30-97-339
which shows you more clearly the kind of connections you are looking at. This one appears to have a few more decimal point/colon connections than yours.
The part either be common cathode like this, so you put ground on a pin and poke around with 5V thru a resistor to see what turns on, or it will be common anode, so you put 5V on a pin and poke around with ground thru a resistor to see what turns on.
Make notes as you go.
« Last Edit: February 21, 2011, 01:05:43 am by CrossRoads » Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Pages: [1]   Go Up
Print
Jump to:
