Topic: steering question (Read 865 times) previous topic - next topic
kevman0044
I am trying to change up some arduino code to accept potentiometer input for variable turn rate. This is what I have right now but I can only tell it turn or dont turn. I need help adding the potentiometer part to it.
//steer one way        SteerValue of 512 is straight ahead
  if (k2 == 1) {
              if (gangleratedeg2 < 5) {    //will turn clockwise at 5 degrees per sec and if not, more power fed into steering until it does
                                           SteerValue = SteerValue + 1;
              if (gangleratedeg2 > 5) {
                                           SteerValue = SteerValue - 1;
//change the 5 and -5 values if you want faster turn rates. Could use a potentiometer to control these values so would have proportional control of steering
//steer the other way
  if (k3 == 1) {
              if (gangleratedeg2 < -5) {    //will turn anticlockwise at 5 degrees per sec and if not, more power fed into steering until it does
              if (gangleratedeg2 > -5) {
    if (SteerValue < 1) {
                    SteerValue = 1;
    if (SteerValue > 1023) {
                    SteerValue = 1023;
    SteerCorrect = 0;
AWOL
Difficult to say from such a brief snippet of code (please use the # icon in the editor's toolbar when posting code), but I think you're going to need to look at "analogRead" and "map".
http://arduino.cc/en/Reference/AnalogRead
http://arduino.cc/en/Reference/Map
Goofballtech
Assuming you are using a servo (because your adjustments are listed in degrees) this page may also help.
http://www.arduino.cc/playground/ComponentLib/Servo
