Topic: 74LS259 Latch with Arduino (Read 840 times) previous topic - next topic
Razor365
Can anyone tell me how to use this latch with Arduino ?
CrossRoads
It has a couple of different modes. What are you trying to do with it?
http://www.ti.com/lit/ds/symlink/sn74ls259b.pdf
Razor365
I just want to drive a 7 segment display with it.
GolamMostafa
#3
Feb 18, 2018, 08:45 am Last Edit: Feb 18, 2018, 08:56 am by GolamMostafa
For what reason (s), do you want to use a 74LS259 Bit Addressable (8-bit) Latch to drive a 7-segment display device when you can directly drive the device using PORTD of the UNO?
Let us look at the MCU burdens to drive only segment-a using PD5 and using 74LS259:
1. Using PD0 bit of PORTD
Code: [Select]
pinMode(5, OUTPUT);
digitalWrite(5, HIGH);                  //segment-a is ON
2. Using 74LS259 Chip
Selection Bits (S2, S1, S0) are connected with: DPins-10, 9, 8
Enable (G/) Bit with : DPin-11
Data Pin (D) with: Dpin-12
Segemnt-1 is connected with Q0-pin of 74LS259
Code: [Select]
DDRB = 0b111111;
PORTB = 0x00;
digitalWrite(12, HIGH);    //Data Bit HIGH
digitalWrite(11, HIGH);    //Enable pulse at G/-pin
digitalWrite(11, LOW);
Do you still want to use 74LS259? Do you want to exercise the use of double for() loops? If so, then drive the segment pins of a 2-digit multiplexed type display unit using 74LS259 and drive the cc-pins of these devices using 74LS138. Write codes to show 2 an 3 simultaneously on these display devices.
Razor365
Yes I know how to drive 7segment by using PORTD pins.But I can't use that. could you please tell me how to use 2 multiplexed seven segment display while segment pins are driven with 74LS259 and cc pins are driven by 74LS138
GolamMostafa
Quote
Learning process does not go this way! A learner is always eager, and he tries to do things (good or bad, working or not working does not matter) based on information what he has received in response to his previous requests. You seem to be different! You should do something and post your works with your results.
Razor365
Actually I was wrong in the 1st place for asking help in this forum. It's useless .
Coding Badly
Quote
Education and Teaching -
Course curriculum, links to existing courses, discussions about experiences at different locations
Yup.  You definitely picked an inappropriate section for your question.
If you want this thread moved to a section where it might get more attention just click Report to moderator.
