Topic: Is there really no way to code this easier? (Read 279 times) previous topic - next topic
Alucard27
Heres a snippet out of my code:
void muster()
    int pack1[] = {10,20,30};
    pick(pack1,1);
    int pack2[] = {25,35,40};
    pick(pack2,1);
void pick(int numbers[],int faktor)
I cant do this:
pick( {10,20,30},1 )
I cant redefine arrays either, what should i do? this is horrible
CtrlAltElite
I cant do this:
Because this is C++.
Here's a snippet of my answer : What do you mea
Has there been an outbreak of the stupid virus, and I didn't get the memo?
econjack
If you've got that info, why not:
//pick( {10,20,30},1 )
   pick(10);
or
   index = 1;
   pick(pack1[index]);
// more code...
void pick(int element)
// code
BulldogLowell
  int pack1[] = {10, 20, 30};
  pick(pack1, sizeof(pack1)/sizeof(pack1[0]));
void pick(int numbers[], int faktor) {
  for (int i = 0; i < faktor; i++)
    Serial.println(numbers[i]);
CtrlAltElite
But that looks nothing like the OP.
Alucard27
Thanks guys, i stumbled over const and now i've changed the code to this:
void muster()
  pick((const int[]){11,21,31}, 1);
  pick((const int[]){18,28,38}, 1);
  pick((const int[]){11,12,13}, 1);
void pick(const int c_numbers[],int faktor)
    int numbers[pick_size];
    for (int i=0; i<pick_size; i++)
        numbers[i] = c_numbers[i];
//Do something with numbers[i]
It works as intended, still thanks!
232
So it works (?) but...
Just for drill, or future reference,look up"passing
An Array to function".
Thunder is good, thunder is impressive; but it is lightning that does the work.
