Loading...
Pages: [1]   Go Down
Author Topic: Digital Multiplexer and storing and comparing digital inputs  (Read 645 times)
Offline Offline
Newbie
View Profile
Hey everyone,
I connected a 74HC151 multiplexer to my arduino board to access a switch matrix, and I'm using a single pin for the digital input from the multiplexer output. How can i store and compare the digital readings of the input? Should I store the readings into an array? Please help. Thanks.
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
That's how I'd do it, something like this.
Code:
byte vals [8];
for (i = 0; i < 8; i++) {
  setMuxAddress(i);  // does whatever is required to set the three select inputs on the MUX
  vals[i] = digitalRead(muxPin);
______
Rob
« Last Edit: February 21, 2011, 10:46:39 am by Graynomad » Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Newbie
View Profile
Thanks, Rob.
Next thing I need to know is how to compare each position in the array. Suppose I have an array of:
[0,1,0,1,0,1,1,1]
with the leftmost position being the first or lowest entry, and the rightmost position is the last or highest entry.
I need to select and compare the positions that has 0 binary value, so that I can transmit serially the highest position that has 0 binary value.
Using the array above as example, I need to select the positions that yielded 0 binary value, which are 000, 010 and 100. Then I need to compare them so that I can get the highest position, which is 100, and transmit it serially.
Thanks.
Logged
Offline Offline
Tesla Member
View Profile
WWW
Just count down from the top until you hit a 0. Something like this...
Code:
for (int i = 8; i ; i--) {
    if (vals[i-1] == 0) {
         Serial.print (i);
______
Rob
Logged
Offline Offline
Newbie
View Profile
Thanks, Rob. It helped a lot.
Logged
0
Offline Offline
Jr. Member
Why is it so?
View Profile
WWW
hmm, i feel somewhat in the dark about your intended goal
in multiple instance similar to yours, i have simply created an array of assigned values to slots. they are binary numbers in decimal representation as well as a state. it will effectively work similar to a debounce, pressing any combination will provide you with a unique sum
Code:
int values[8] = {1,2,4,8,16,32,64,128};
int state = 0;
int current = 0;
 // reset current
 current = 0;
 for(int n = 0; n < 8; n++){current += digitalRead(n) == LOW ? values[n] : 0;}
 if(state != current)
      do something here to execute on value change
   // set state to current
   state = current;
my two cents
Logged
Pages: [1]   Go Up
Print
Jump to:
