Topic: Alternative/better IDE (Read 6104 times) previous topic - next topic
dexxsterlab
Hi, any suggestions for alternative/better IDE's for Arduino ?
Thanks in advance.
PaulS
There are no better IDEs for Arduino. The one provided is perfect. Just ask the Arduino team. That seems to be the standard response to every enhancement request.
On the other hand, if you described what YOU mean by a better IDE, perhaps some more useful suggestions could be proposed.
dexxsterlab
Nothing is perfect. And the current IDE is far from perfect. I just wanted to use a better editor (and program the board from that) and not that awful standard IDE, but probably there's no hope... Thanks.
Graynomad
Quote
There's plenty of hope. Some folks use Eclipse and I've been using Netbeans for a while but really I find all those big IDEs are a lot of bloatware, so just recently, in an effort to get back to basics I moved to using Notepad++ for an editor and running a makefile in a dos window.
Notepad++ is a great editor and using a makefile gives you total control over the build process.
Just like the "old" days.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
dexxsterlab
Rob,
can you please send me the makefile ?
I like Notepad++ very much, it's my main editor and I think that your arrangement is much better than the standard IDE (I tried, but I don't like it at all).
Thanks in advance,
John
robtillaart
IN the file menu choose preferences and select external editor :)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Graynomad
Makefile attached
Note the following.
This works in my environment and I use it to program two different 328-based boards. It's not necessarily robust and I may have broken something in the original file that I don't use.
I just tried it on my Mega and avrdude didn't sync (feel free to fix this :))
I haven't used make for about 15 years so my changes may be a little non kosher.
I think it could be cleaned up more, there's a lot of stuff I don't need.
______
Rob
frank26080115
In order of my preference
AVR-Project-IDE
Eclipse, Netbeans
Anything using Scintilla
Graynomad
#8
Feb 22, 2011, 06:47 am Last Edit: Feb 22, 2011, 06:54 am by Graynomad Reason: 1
Quote
I just tried it on my Mega and avrdude didn't sync (feel free to fix this )
I've fixed this, change the part between double ##### lines to this
Code: [Select]
# Select processor line here
MCU = atmega328p
#MCU = atmega2560
ifeq ($(MCU),atmega2560)
UPLOAD_RATE = 115200
AVRDUDE_PROGRAMMER = stk500v2
COM = 39
endif
ifeq ($(MCU),atmega328p)
UPLOAD_RATE = 57600
AVRDUDE_PROGRAMMER = stk500v1
COM = 33
endif
ARDUINO_VERSION = 21
PROJECT_NAME = quubmon_client
PROJECT_DIR = d:/work/quubmon/client
ARDUINO_DIR = c:/progra~1/arduino/arduino-00$(ARDUINO_VERSION)
ARDUINO_CORE = $(ARDUINO_DIR)/hardware/arduino/cores/arduino
ARDUINO_AVR =    $(ARDUINO_DIR)/hardware/tools/avr/avr/include/avr
ARDUINO_LIB = $(ARDUINO_DIR)/libraries
AVRDUDE_PATH = $(ARDUINO_DIR)/hardware/tools/avr/bin
AVRDUDECONFIG_PATH = $(ARDUINO_DIR)/hardware/tools/avr/etc
AVR_TOOLS_PATH = c:/progra~1/atmel/bin
AVR_INC_PATH = c:/progra~1/atmel/avr/include/avr
PORT = //./COM$(COM)
F_CPU = 16000000
I've got different COMs because I'm working on two different boards at the same time.
______
Rob
dexxsterlab
Thanks everyone for your precious suggestions.
vipersnh
can somebody mod the code-blocks for compiling ide out of box.. (its an open source ide)..
Udo Klein
I use Linux and prefer Kate ;)
Check out my experiments http://blog.blinkenlight.net
gadjet
I've been using Arduino for a couple of months now and I really like it but I agree that the IDE is OK but not the best IDE I've used but what do you expect for free!
I've used Notepad++ for a while and I thought I'd give it a try for sketches, WOW it's brilliant.
I found the NPPExec plugin for Notepad++ and, if I understand it correctly, it can run scripts to run external compilers etc.
Has anyone got any experience using this pugin with Notepad++ to drive the make process etc.
Or some other options: -
  • Can we request the Authors of the Arduino IDE to make a plugin for Notepad to give us a button to compile the Sketch?
  • Add some of the features found in notepad++ to the Arduino IDE, like auto indent, highlight matching words, auto grouping by braces.
Just some of my thoughts.
Udo Klein
The IDE offers an "external editor" mode. This will disable the internal editor and the IDE will only upload. Do not forget to save before doing so.
The alternate approach is to use a makefile / sconstruct and let Notepad++ call it.
Graynomad
I've been using Notepad++ for some time, it's a great editor. So far I've found it easy to ALT-TAB to a DOS window and run make from there.
Does NPPexec make this any easier/better? As usual with sourceforge stuff I can't find any documentation.
______
Rob
