Topic: audio buffers ? (Read 2224 times) previous topic - next topic
julienbayle
hello,
very new to arduino / audio circuits (I'm more in interfacing and protocols til today :p), I'd like to figure out the process from outputs pins to speaker.
is it:
arduino pins output ====> DAC ====> buffer ====> speaker ?
I 'd like to understand why these buffers are required and if I'd need a kind of anti-aliasing filter or not?
all the best,
Julien
http://julienbayle.net
CrossRoads
Antialiasing is not used on the output - usualy there is just a low pass filter to take out high frequency switching noise.
Antialiasing is done on the input side - say you are capturing data with at 20KHz sample rate  - then antialiasing filter would be a filter that kept the input frequencies below 10 KHZ (since you need at least 2 samples to be able to recreate a waveform). This could also be a low pass filter.
julienbayle
hi both mate :)
thanks a lot
now, it is clear in my head.
if you're interested, I'm currently designing an open-source sound machine: http://arduino.cc/forum/index.php/topic,53074.msg379063.html#msg379063
Julien
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
