Topic: kit of component for starter... where? (Read 943 times) previous topic - next topic
rfrp
Hi all!
I'm coming back to develop projects with my arduino after a pairs of years. I have been buying some components, but i'm in doubt about what i should buy... there is a common kind of component that are usefoul for many common project? What i can avoid? go to the electronic store to buy, for example... 2 resistor of 1omh by say something...
So, any clue? A link for a kit?
Thanks a lot!!
Roberto
CrossRoads
go to dipmicro and grab their collections of parts
http://www.dipmicro.com/store/index.php?page=5&act=viewCat&catId=470  scroll down
http://www.dipmicro.com/store/index.php?page=11&searchStr=resistor&act=viewCat&Submit=Search
http://www.dipmicro.com/store/SET-LED5
or at least a bunch of 270 ohm resistors, 0.1uF caps, NPN transistors or ULN2803 driver chips (8 drive transistors).
Some 74HC595 shift out registers
5V power supply, with 5.5/2.1mm plug
some push button  switches
http://www.dipmicro.com/store/index.php?act=viewCat&catId=548
Browse around, get some ideas, costs are really good and shipping is low.
Maybe a spare ATmega328 in case you damage one.
I don't see any 7-segment displays, maybe pick up a few of those (common anode) and maybe some LED matrixes?
http://www.mpja.com/products.asp?dept=121
tkbyd
There's a nice assortment for $20 called the "Experimenter's Pack" available from...
http://wulfden.org/TheShoppe/accessories.shtml
.. a good source for all sorts of things. Be sure to include in your order a few of their mini breadboards.
rfrp
Thank you very much!
I will look and if i have another doubt i will ask here again ;)
Greets!
Roberto
CrossRoads
Update your geographic profile Roberto, helps us make knowledgeble source suggestions also.
rfrp
CrossRoads, i have updated my location. By the way i'm on Santiago of Chile in South America.
Greets,
Roberto
CrossRoads
What do you have available for electronics suppliers there? Be expensive to have stuff shipped from the US I would think.
Benji
You'll probably have an idea of what to get now, but the one thing I didn't see anyone mention is:
If you buy something like resistors, don't get just the two you need. If you need two, get ten. If you need ten, get twenty.
You'll always find yourself in a situation like "I need this 'n that resistor NOW" and your box with resistors of that specific value is empty.
Since they come pretty cheap in most cases it's no problem getting a couple extra's.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
