Topic: réception 433 Mhz (Read 1 time) previous topic - next topic
nexen
j'ai parlé de la lib "rcswitch" pour exemple en disant bien qu'il faudrait surement utiliser quelque chose de plus generique.
de plus certaines questions restent encore en suspend
quelle carte arduino utilisez-vous ?
quels sont vos émetteur-récepteur 433MHZ ?
comment avez-vous procedé a vos tests ?
biggil
Si la bibliothèque RCswitch ne reconnait pas le protocole utilisé, c'est normal que tu ne détectes rien - et dans ce cas il n'y a nulle part où aller chercher les données.
fadom10
Je sui sur la uno
Mon récepteur est la Rx433
fadom10
C'est bon j'ai la Data via l'exemple !! (en cliquant une fois sur le bouton "test" du capteur de fumée) :
Decimal: 76300 (24Bit) Binary: 000000010010101000001100 Tri-State: not applicable PulseLength: 393 microseconds Protocol: 1
Raw data: 12216,460,1136,456,1140,452,1144,452,1148,444,1156,440,1156,428,1176,1184,416,424,1176,420,1176,1184,412,416,1180,1188,400,424,1172,1196,400,424,1176,428,1168,432,1164,428,1176,436,1164,1200,396,1200,396,428,1164,432,1172,
Decimal: 76300 (24Bit) Binary: 000000010010101000001100 Tri-State: not applicable PulseLength: 394 microseconds Protocol: 1
Raw data: 12184,492,1108,484,1108,488,1112,480,1116,476,1124,468,1128,444,1156,1208,396,436,1160,436,1160,1204,396,432,1160,1204,388,436,1164,1204,388,432,1172,436,1156,440,1156,440,1156,436,1160,1208,392,1204,392,428,1172,428,1160,
Raw data: 12188,488,1112,484,1112,476,1120,476,1124,468,1124,468,1132,440,1156,1208,396,436,1156,440,1160,1208,388,436,1164,1204,388,436,1164,1204,392,436,1164,440,1160,432,1160,440,1156,444,1156,1208,392,1200,392,436,1160,444,1164,
Decimal: 76300 (24Bit) Binary: 000000010010101000001100 Tri-State: not applicable PulseLength: 391 microseconds Protocol: 1
Raw data: 12252,428,1172,420,1180,416,1180,412,1188,408,1188,404,1188,464,1136,1220,388,440,1156,436,1168,1200,392,432,1168,1196,396,428,1160,1208,392,428,1172,436,1160,436,1160,436,1164,440,1156,1208,388,1204,392,428,1168,432,1168,
Decimal: 11184652 (24Bit) Binary: 101010101010101000001100 Tri-State: not applicable PulseLength: 394 microseconds Protocol: 1
Raw data: 12224,1220,380,440,1156,1208,392,432,1164,1204,392,432,1156,1212,384,440,1164,1208,384,444,1156,1204,396,428,1164,1200,396,428,1168,1200,396,428,1180,424,1164,432,1164,436,1164,432,1164,1204,396,1196,400,424,1176,424,1164,
nexen
nickel, le projet avance.
fadom10
Up, quelqu'un peut me dire ce que cela signifie ?  :smiley-confuse:
biggil
1 - la bibliothèque que tu utilises reconnait le protocole de l'émetteur.
2 - la donnée reçue est 76300
nexen
et pour compléter la réponse de biggil je vais ajouter ceci:
pour envoyer la même commande depuis l'arduino il faudra ajouter cette ligne a votre code "mySwitch.send(76300, 24);" (en ayant bien évidament branché convenablement l'émetteur rf433)
