Topic: Combining digits from the keypad.getKey() function (Read 3891 times) previous topic - next topic
SouthernAtHeart
Keypad matrix, using the library:
http://arduino.cc/playground/Code/Keypad
Code: [Select]
void loop(){
  char key = keypad.getKey();
  if (key != NO_KEY) {
    Serial.println(key);
If the user wanted to input the number 10, how would I 'get' that number from the two keypresses '1' and '0'
I haven't written any code yet for the keypad, but here's what I'm thinking:
lcd.print:  "Enter the number of cups of coffee & press #"
     user can enter a number (2,4,6,8,10)
So if they they enter 2 digits, I need to combine them into 1 variable.
CrossRoads
Well, just take the inputs & do some math on it:
before reading clear the prior entries
digit1 = 0
digit0 = 0
after you get the entries
total = 10*(digit1) + digit0
Or, you will have a 4x3 keypad?
Make one of the keys = 10.
1-2-3-4-5-6-7-8-9-10-enter-clear
0 = 10,
# = clear,
* = enter
SouthernAtHeart
digit1 = 0
digit0 = 0
0 = 10,
# = clear,
* = enter
Thanks, yes, 3x4,
I see now.  I could do either of these...
YT2095
i`m just wondering about the maths part, as to whether it would still parse as ASCII?
and thus be useless for any Math type functions.
the only reason I`m bringing up this old(ish) thread is that I had a similar problem trying to parse these numbers as REAL ones rather than some arbitrary ASCII equiv.
after a good mess about I discovered that you CAN in fact do this with the keypad Lib, my HEX keymap now looks like:
char keys[ROWS][COLS] = {
  {0x000c,0x000d,0x000e,0x000f},
  {0x0008,0x0009,0x000a,0x000b},
  {0x0004,0x0005,0x0006,0x0007},
  {0x0000,0x0001,0x0002,0x0003}
This isn`t the End of my Journey yet, as I still need to then push these out to 1 Byte serial piso 74595`s yet ( 3 of them) 2 for Address and one for Data.
but it`s enough to perhaps help Some along the way ;)
All the best!
robtillaart
#4
Apr 06, 2011, 08:02 pm Last Edit: Apr 06, 2011, 08:07 pm by robtillaart Reason: 1
as char is only one byte big your char map should be
 {0x0c,0x0d,0x0e,0x0f},
 {0x08,0x09,0x0a,0x0b},
 {0x04,0x05,0x06,0x07},
 {0x00,0x01,0x02,0x03}
but better use the chars directly in your array :
char keys[3][4] = {
 {'7','8','9'},
 {'4','5','6'},
 {'1','2','3'},
 {'*'.'0'.'#'}
or use the int values you want except for the * and # all is possible.
char keys[3][4] = {
  {7,8,9},
  {4,5,6},
  {1,2,3},
  {'*',0,'#'}
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
YT2095
yeah, this is still a bit new(ish) to me, the problem that I`m going to (have already) hit, is concatenating 2 Hex values into a single byte to push out to the Hardware serial array.
I certainly can`t Add them. and I see no Nibble Splice command??????
and my Math is pathetic on a Good day :)
CrossRoads
upper_nibble = upperByte<<4 ; // shifts bits 4 left, leaving 0bXXXX0000 (or whatever the prefix is for BITs)
lower_nibble = 0x0F & lowerByte; // Zero's out upper bits, leaving 0b0000YYYY
combined = lower_nibble | upper_nibble; // ORs together for 0bXXXXYYYY
