Topic: 12 volt shield (Read 2137 times) previous topic - next topic
stone
I wonder if there is a thing such as a "12 volt shield" which converts all outputs/inputs of Arduino Mega to 12 volts? I need to connect several 12 volt sensors to an Arduino Mega. 12 volt output (low current) is also needed. I would preffer to buy a readymade shield.
robtillaart
have you checked - http://shieldlist.org/ - many shields there :)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
stone
I checked http://shieldlist.org/ and also Googled for a 12 volt shield. I haven't found a good match.
robtillaart
for (digital) input you could make simple voltage dividers  - http://www.bowdenshobbycircuits.info/r2.htm
for output you can use a relay shield? or is that too slow? - http://shieldlist.org/seeedstudio/relay
maybe this helps more :)
Rob Tillaart
Grumpy_Mike
I know of no such ready built shield for this sort of thing. I doubt if you will find one, it is rather an odd request.
stone
Thanks. The relay shield only has four outputs.
This shield does not adress the input problem. A resistor on the input pins would probably do (optocouplers would be better), but as I mentioned, I would like to purchase a readymade board which plugs into the Arduino Mega.
It would be perfect if there was a board which converted all Arduino Mega pins to 10, 12 or 24 volts (depending on the voltage of the external source).
robtillaart
Thinking out loud,
Cars use 12Volt for all kind of things, and they sometimes use the CAN-bus  (Car Area Network). So an Arduino shield with CANbus and some CAR-electronics?
- http://shieldlist.org/sparkfun/can-bus
- http://www.squarell.com/Products/Components/component/27
Rob Tillaart
robtillaart
some recent canbus activity...
- http://arduino.cc/forum/index.php/topic,52052.0.html
Rob Tillaart
stone
Thanks,
Decided to build my own board using voltage dividers at the input and transistors for the output. 12/24 volt output/input is quite common, so eventually somebody will manufacture a board...
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
