Topic: MKRFOX1200 Questions (Read 985 times) previous topic - next topic
AntonioRiccelli
Feb 26, 2018, 04:17 pm Last Edit: Feb 26, 2018, 04:24 pm by AntonioRiccelli
Hello Everybody
I would like to know if the MKRFOX1200 is able to receive a string from the BACKEND that was previously sent via the external API so that the device would activate, for example, some digital output ...
Thank's
Antonio
Meric
Hi there,
I think this is the answer you need.
Aurelien said :
For the arduino sketch, you can look at the FirstConfiguration example (https://github.com/arduino-libraries/SigFox/tree/master/examples/FirstConfiguration):
The downlink is triggered by setting the endPacket() method to true, then use SigFox.read() to retrieve received bytes:
Code: [Select]
int ret = SigFox.endPacket(true);  // send buffer to SIGFOX network and wait for a response
if (SigFox.parsePacket()) {
    Serial.println("Response from server:");
    while (SigFox.available()) {
      Serial.print("0x");
      Serial.println(SigFox.read(), HEX);
If you need information on how to configure the downlink on sigfox backend, you can refer to this guide:
https://github.com/nicolsc/sigfox-downlink
Aurelien
Enjoy'
Méric
horace
after following the instructions sigfox-downlink you can test the downlink using a service such as PutsReq which records HTTP requests and allows the creation of a response, e.g.
1. create a PutsReq
2. copy the URL into the Sigfox backend CALLBACK URL pattern and save the callback
3. in the PutsReq Response Builder enter
response.status  = 200;  // default value
response.headers['Content-Type'] = 'application/json';
response.body = {"XXXXX":{"downlinkData":"70117f61a5ceec67"}}
where XXXXX is your device ID
on the next uplink you should get a downlink to the device, e.g.
Code: [Select]
MKRFox1200 Sigfox
SigFox FW version 2.3
Module temperature: 20.00
Type the message to be sent
Sending 6
Getting the response will take up to 50 seconds
The LED will blink while the operation is ongoing
Transmission ok
OK
PA OFF
0x70 0x11 0x7F 0x61 0xA5 0xCE 0xEC 0x67
