Loading...
Pages: [1]   Go Down
Author Topic: Question about 74hc595 and 8x8 RGB Matrix  (Read 1600 times)
my own world
Offline Offline
Newbie
We are all geeks!
View Profile
I have:
1 - 8x8 Common Anode RGB matrix
4 -  74hc595 shift registers.
According to the following schematic each chip is responsible for one color and 1 chip for the anodes..
What dictates what chip will handle which color? And what dictates which one will be the chip serving the anodes?
I have built the following schematic on a breadboard, when I  was done the colors and the anodes were wrong.
A little testing and I was able to figure out what chip = what color and what the anodes were.
Rewired, the breadboard circuit worked perfect.
Before I build this onto a pcb  and solder it, I want to make sure I have the correct layout correct
All credit for this schematic goes to: Francis Shanahan
Logged
Signatures are stupid!
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Functionally it looks good. Check the actual pin numbers against the datasheet.
You may want to break out cathode OE/ pins so you can drive them with separate PWM pins for fading/color shifting, vs off or full on.
Which RGB display are you using?
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
I suggest to put a 10k pullup on the common OE line and wire it to a pin on the arduino. From personal experience with this way of driving an RGB matrix I can tell it is useful ;-)
If you're thinking about doing 'true color' with software pwm, you will need it. Otherwise you may notice that the last line looks inexplicably brighter than the remaining 7. Also you can put another 595 in parallel with the one driving the anodes for a bit more brightness. Ideally add a source driver like the UDN2981A to it and while we're at it replace the other 595 with real drivers like MBI5168. Then you'll also have to send the appropriate amount of blanking data to the drivers, or you'll see ghost images.
Some more info can be found on my blog, if desired ;-)
Logged
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
my own world
Offline Offline
Newbie
We are all geeks!
View Profile
Thanks for the replies guys..
Yes the last line was a lot brighter than the rest... smiley-confuse
Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
Try sending 4 zero bytes at the end of your function that talks to the matrix.
Logged
Pages: [1]   Go Up
Print
Jump to:
