Loading...
Pages: [1]   Go Down
Author Topic: Is it safe to connect a #30 bulb directly to the arduino output pin  (Read 647 times)
Washington
Offline Offline
God Member
Firefox & Arduino rocks
View Profile
http://www.bulbtown.com/30_MINIATURE_BULB_WIRE_TERMINAL_BASE_p/30.htm
Is it safe to drive directly from a pin?
Logged
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Maybe ... The specs seem to say it has 21mA current draw at 4.5V
I think I'd measure its 2 leads, see if it has reading of around 200 ohm to confirm that.
Or get a current measurement while powering from 3 AA batteries for confidence first.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Well the spec sheet says:  4.5 Volt 0.021 Amp. So that would on the surface say it would work great with an Arduino output pin. However (seems there is almost always a however) incandescent lamps have a property that initially there cold resistance will be lower then it's running resistance. So what is it's inrush current, and would it exceed the Arduinos absolute 40ma limit. I don't know, do you? I guess you could measure it's cold resistance to see how bad a situation it might be, but that doesn't tell you how fast it's resistance increases from inital turn on.
 I would rather ask, why use an incandescent lamp at $2.73 a pop, marked down from $3.25? High brightness white leds are cheaper (.32 each in bulk, link below) then that and have no current inrush problem, and don't burnout like incandescent lamps.
http://www.sparkfun.com/products/9850
Lefty
« Last Edit: February 23, 2011, 01:25:30 am by retrolefty » Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
No, it's not safe.
In cold state resistance approx. 10 times less than it in hot condition.
It would overload output when turn on up to 200 mA, that is too much.
Logged
Washington
Offline Offline
God Member
View Profile
The measured current draw at 4.8v input is 26ma.
Quote
 I would rather ask, why use an incandescent lamp at $2.73 a pop, marked down from $3.25? High brightness white leds are cheaper then that and have no current inrush problem, and don't burnout like incandescent lamps.
A. I already have one
B. It casts omni directional light
C. It can be PWM'd without flickering.
Logged
Resistors for LEDS!
Offline Offline
Brattain Member
View Profile
Well if you must use it, just have a transistor do the current switching with the arduino output pin controlling the transistor.
Have you ever tried diffused leds, I use them in my 5x5x5 led cube and they can be seen from any angle, even from their bottom where the leads come out.
 That should be something you can 'fix' with software, leds don't flicker on their own.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
C. PWM. Isn't normal PWM at 490-500 Hz? Can you see that flickering? I thought above 24H the brain put it together as steady. Good computer monitors used to go 60Hz, maybe 72. 500 for an LED would seem sufficient.
http://www.dipmicro.com/store/LED5W $0.26
Shipping $2.50
Get some other stuff at the same time, the price really drops with at qty 4 and then again at 10.
1 = 26 cents. 4 = 63 cents total.  10 = 94 cents total. 20 = $1.47 total.
Get some other colors for your next project!
You run one of these bad boys at 20mA, will seem omnidirectional it is so bright! I've read if you lightly sand the outside to diffuse it, will seem even more so.
Logged
Washington
Offline Offline
God Member
View Profile
I already have a high brightness LED and it has noticeable flicker at the low end of the PWM.
Logged
Resistors for LEDS!
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Try putting a cap in parallel to smooth it out.
Logged
Washington
Offline Offline
God Member
View Profile
I guess I will hook the bulb up with an external transistor.
Is a 2N2222 acceptable?
Logged
Resistors for LEDS!
Offline Offline
Brattain Member
View Profile
Yes it is.
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Quote
Well that's weird...
Logged
Pages: [1]   Go Up
Print
Jump to:
