Topic: LCD Thermostat (Read 2842 times) previous topic - next topic
nitro_boy
Hi all !!
I'm very new to lcd codes and i've made a simple thermostat but now i have a problem that I don't know how to make a menu on my LCD.
The menu should have two items so that I can manualy turn two outputs ON and OFF, with 2 buttons ( forward, select) to get to the menu I vould press both buttons.
Can you help me ?
Code: [Select]
#include <LiquidCrystal.h>
 int  ledPin = 8;
 int  TEMPTRIGGER = 25.00;
 float temperature = 0;
 LiquidCrystal lcd(10, 11, 12, 13, 14, 15, 16);
 pinMode(ledPin, OUTPUT);
 lcd.begin(16, 2);
 lcd.setCursor(0,0);
 lcd.print("Made By Elvis K.");
 lcd.setCursor(0,1);
 lcd.print("Prosim pocakaj...");
 delay(2000);
 lcd.clear(); // clear LCD screen
 lcd.setCursor(0,0);
 lcd.print("Temperatura je: ");
 if(temperature >= TEMPTRIGGER) {
   digitalWrite( ledPin, HIGH);
   delay(100);
   digitalWrite( ledPin, LOW);
   delay(100);
   lcd.setCursor(0,0);
   lcd.print("  ALARM ALARM  ");
     else{
       lcd.setCursor(0,0);
 temperature = analogRead(5); /
 temperature = temperature +252-500;
 temperature = temperature / 10;
 delay (100);
   lcd.print(" Temperature is   ");
   lcd.setCursor(0,1);
   lcd.print(temperature);
   lcd.println(" stop. C.   ");
Thanks !
johnwasser
Some things to do:
You'll need to keep track of what state the display is in.  If you are displaying a menu you don't want to also be displaying the temperature.
When you are not displaying the menu you should ignore a button being pressed unless both buttons are pressed.
When you are displaying a menu you should ignore a button being pressed if it was already pressed the last time you checked or if the other button is already pressed.
You want to somehow highlight the selected line, perhaps with a ">" in the left column.  When the "next" button is pressed you want to move the pointer.  When the "select" button is pressed you want to perform the selected action and go back to displaying the temperature.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
nitro_boy
that is exactly what i'm trying to do, but I don't know how :D
nitro_boy
nitro_boy
I found this but don't know how  to implant it in to my code.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1273349195/45
Is there really nobody that wants to help me ?
rolandoo
Hello
Did you find solution for a problem to make a menu on LCD?
I have the same problem, can you help me?
Thank you in advace
