Topic: Reading Pitch Roll from CHR6DM (Read 7959 times) previous topic - next topic
AWOL
OK, so just loop reading and discarding input until you find an 's'.
Then read your message in one character at a time, or, having seen the 's', wait until available returns 16, and then read them in.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
nturpin77
Yes ideally I am waiting for the 's" byte and then 7 bytes after that are the values I am looking for.
AWOL
Code: [Select]
while (Serial.read () != 's') ;
PaulS
Quote
Quote
According to the CHR6dm data sheet the data is output in byte chunks starting with an 's' as the beginning of the packet burst and follows with 'n' 'p'. There is two 8 bit byte values following that describes the packet type and another 8 bit byte value to tell how long the packet is. Following these values are the registers in 8 bit format that are the actual pitch roll yaw values each taking up two registers so there would be a Pitch1/Pitch2 Roll1/Roll2 Yaw1/Yaw2 that when put together give the values for Pitch Roll and Yaw.
So, the 7 bytes of interest are the 'n', 'p', 2 for packet type, 1 for packet size, and 2 for pitch?
nturpin77
Sorry for the mistype PaulS its the 'snp' PacketType and PacketNumber are discarded. From my previous coding it was the first 7 bytes that are discarded and everything after those 7 bytes are what Im looking for. I just use the 's' as the start of the packet.
nturpin77
AWOL
But if I do that while statement wont it just take everything other than the 's' regardless of character location? For example what if it starts reading mid stream, sure it could get data but it could start at the Yaw Accelerometer and thats not the data Im looking for.
N
AWOL
Quote
Absolutely, so when the "while" exits, you can be sure you've received a start of packet.
The next character should be an 'n'
nturpin77
Here is my updated code. Already know it doesnt work. But it is reading the serial port because when I unplug the pitch roll sensor the 0's stop flowing....
Code: [Select]
  while(Serial.read() != 'p');
    int PT1 = Serial.read();
    int PT2 = Serial.read();
    int DATAN = Serial.read();
    byte Yaw1 = Serial.read();
    byte Yaw2 = Serial.read();
    byte Pitch1 = Serial.read();
    byte Pitch2 = Serial.read();
    byte Roll1 = Serial.read();
    byte Roll2 = Serial.read();
    int YawVal = (int)((((Yaw1 << 8) | Yaw2) << 16) >> 16);
     double YawCalc = YawVal * 0.0109863;
     int PitchVal = (int)((((Pitch1 << 8) | Pitch2) << 16) >> 16);
     double PitchCalc = PitchVal * 0.0109863;
     int RollVal = (int)((((Roll1 << 8) | Roll2) << 16) >> 16);
     double RollCalc = RollVal * 0.0109863;
     Serial.print("$CTAP,R,");
     Serial.print(RollCalc);
     Serial.print(",P,");
     Serial.print(PitchCalc);
     Serial.print(",Y,");
     Serial.println(YawCalc);
AWOL
Code: [Select]
You are STILL reading characters that may not be there!
Why don't you use "available()"?
http://arduino.cc/en/Serial/Read
http://arduino.cc/en/Serial/Available
nturpin77
Ive tested this bit of code and I can fill the buffer and spit the buffer out.
Code: [Select]
  byte CHRbuffer[17];
  int CHR;
  if (Serial.available())
    while(Serial.available())
      CHR = Serial.read();
      CHRbuffer[j] = CHR;
      j++;
  j=0;
  while (Serial.available())
    Serial.print(CHRbuffer[j]);
    j++;
AWOL
So why don't you apply what you've done there on your code above?
nturpin77
Heres what I have done now and the code seems to hold other than the fact sometimes Ill get erroneous data or the data will stop randomly. Is the arduino prone to losing data at high baud rates?
Code: [Select]
float CHR_yawClean;
float CHR_pitchClean;
float CHR_rollClean;
byte CHRbuffer[22];
#define YAW_FACT 0.0109863F
#define Pitch_Fact 0.0109863F
#define Roll_Fact 0.0109863F
int j = 0;
  int CHR_yawWord, CHR_pitchWord, CHR_rollWord;
  byte CHR;
      CHRbuffer[j] = Serial.read();
      if (CHRbuffer[j] == 's')
        char n = Serial.read();
        char p = Serial.read();
        byte PT1 = Serial.read();
        byte PT2 = Serial.read();
        byte DN = Serial.read();
        byte space = Serial.read();
        CHR_yawWord = (int)Yaw1 << 8;
        CHR_yawWord |= Yaw2;
        CHR_pitchWord = (int)Pitch1 << 8;
        CHR_pitchWord |= Pitch2;
        CHR_rollWord = (int)Roll1 << 8;
        CHR_rollWord |= Roll2;
        CHR_yawClean = (CHR_yawWord * YAW_FACT);
        CHR_pitchClean = (CHR_pitchWord * Pitch_Fact);
        CHR_rollClean = (CHR_rollWord * Roll_Fact);
        Serial.print("YAW: ");
        Serial.print(CHR_yawClean);
        Serial.print(" Pitch: ");
        Serial.print(CHR_pitchClean);
        Serial.print(" Roll: ");
        Serial.print(CHR_rollClean);
      j++;
  j=0;
delay(350);
AWOL
Code: [Select]
You've been told only that there is at least one character available, but you read two or more.
Have you read what I've been saying about not doing this?
nturpin77
I put in
Code: [Select]
while(Serial.available() > 0)
and removed the
Code: [Select]
I dont think the first if statement is really needed if I have the while right after. So the data doesnt freeze like it used to but I still get erroneous data every 4th reading which almost too reliablely unreliable LOL
AWOL
#29
Mar 04, 2011, 01:51 pm Last Edit: Mar 04, 2011, 01:56 pm by AWOL Reason: 1
Think about what happens.
At 115200 baud, a character takes 86 us to transmit.
Serial.available returns 1 when the serial receiver has buffered a character.
So, you go and read out that character and compare it to the letter 's'.
Maybe 5 microseconds (being generous here) have passed - not long enough to have received another character.
The character was an 's' (let us say), so you go ahead and read another character.
But no character has arrived yet.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
