Topic: Timing problems - timer2 and SPI (noob) (Read 1 time) previous topic - next topic
wossname
I think I've made a design mistake.  I was hoping to drive a pair of cascading shift registers by using the SPI.h functionality, and have my timing dictated by using timer interrupts running at 7800 hertz or so.
I can do EITHER of these things independently: run the shift registers (in a hard-coded loop) OR use the interrupt (TIMER2 calls a test function).
But I cannot seem to make the interupt drive the shift registers.
Is there some contention between timer usage and SPI?
(Sorry, I had to re-post this because I screwed up the original description of the problem  :smiley-red:)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
