Topic: ESP8266 receive serial data and transmit on UDP (Read 368 times) previous topic - next topic
sayra_nandhan
Hello,
I want to read the incoming string from the microcontroller and transmit the same in UDP. The UDP data gets transmitted bit by bit and not as a whole. Please guide me through this. My code is as below,
  while (Serial.available())
    char inChar = (char)Serial.read();
    inputString += inChar;
    Serial.printf("%c", inChar);
    Udp.endPacket();
    Udp.beginPacket(IP, 7727);
    Udp.write(inChar);
    Udp.endPacket();
rw950431
Welcome to the forum!
What is the problem you are having?  How does this small piece of code fit in your complete program?
(And please use the code tags </> to nicely format your code..)
PaulS
Quote
You wrote the program that way, so I'm not surprised.
You need to define what "a whole" means. Serial data is just a bunch of bytes. You have to collect the bits and pieces until you have what you consider "a whole", and then send that.
