Topic: Library for TFT (Read 250 times) previous topic - next topic
AdityaRD
I recently purchased a TFT shield - 3.5" UNO MODULE.
I can't find a suitable library for this module.
Specifications :
Driver-HX8357C
Bus-8 bit
Dots-320×480
SKU-MAR3501
Touch-Yes
I am currently using Arduino Uno R3.
Please suggest me a suitable library.
Thank you .
robtillaart
Have you asked the shop you purchased the display from?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
david_prentice
#2
Mar 08, 2018, 07:51 pm Last Edit: Mar 08, 2018, 07:54 pm by david_prentice
Specifications :
Driver-HX8357C
Bus-8 bit
Dots-320×480
SKU-MAR3501
Touch-Yes
Please post a link to the actual item you have bought.    If it is a Uno Shield,   I suspect it has either a Blue or Red pcb with regular Mcufriend wiring.
Please install MCUFRIEND_kbv via the IDE Library Manager.
If the barcode label on your display said HX8357C I will be very grateful if you could run the sketch in this message
David.
AdityaRD
Yes I had asked him, but even he didnt know.
He instead told me to search online.
AdityaRD
David.
I didnt find the exact shield on the net but I have found a similar one but mine doesn't have the white port on the top right side and company name is also not written.
It is a blue PCB. I will run the sketch and reply back.
(https://www.amazon.in/Phenovo-Screen-Shield-Module-Arduino/dp/B076M7LKRB?tag=googinhydr18418-21&tag=googinkenshoo-21&ascsubtag=1faf6d69-cff8-44f6-b618-6145c523e1a5 )
david_prentice
I call that display "Blue 3.5 inch Mcufriend".
The photo with the white flex-ribbon connector is probably ILI9481.
It plugs into a Uno.   It should work with MCUFRIEND_kbv library.
It should work with the sketch that I linked to in #2.
David.
