Loading...
Pages: [1]   Go Down
Author Topic: LED Marquee python script  (Read 996 times)
berlin
Offline Offline
Full Member
fubbi.com
View Profile
I am communicating with a scrolling LED marquee using a python script, instead I would like to send the serial data myself
This is what I tell it in the terminal:
Code:
python toledo.py -p "/dev/tty.usbserial" --link="A" --output
It is very difficult to extract the relevant serial bits for me since I don't know whats what in the script.
What is the serial data for:
--link "A" (select program on the marquee A,B, C, D etc)
and
--output (execute!)
If someone could look at the attached script I would be immensely grateful!
fubbi
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
do you have a datasheet of the scrolling LED marquee thingie?
The python script merely sets all kind of commandstrings to get certain effects / fonts etc. These are just ascii strings (saw no binary in my quick scan) so easy to mimic yourself. If you call the script with the debug flag you will get the whole string in your console window. And you will see the codes otherwise send to the board.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
berlin
Offline Offline
Full Member
fubbi.com
View Profile
Hi
I unfortunately have no datasheet, but luckily I found a python script someone wrote for that display and got it to work.
Anything sent to the board must be in the script somewhere right? Where else would it come from?
thanks
fubbi
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
1) Yes
2) Could be in internal memory of the device, triggered by some code
Can you post a picture of the device, or better are there typenumbers or other info on it?
Logged
Rob Tillaart
berlin
Offline Offline
Full Member
fubbi.com
View Profile
this is the page where i found the script http://freezerpants.com/toledo/
and this is the sign (the one with red leds): http://www.amplus.com.hk/LED_%20AM03127-H13.htm
the python script was the most info I could find so far
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
The python script contains quite a lot of codes, you only have to port that to an Arduino sketch e.g in the form of a Serial.print("<FL>"); for snowflake effect
Have you tried the debug flag yet? then you will see what needs to be send. So please post the debug output.
Logged
Rob Tillaart
Netherlands
Offline Offline
Tesla Member
View Profile
also tried :  python toledo.py --help    ?
Logged
Rob Tillaart
berlin
Offline Offline
Full Member
fubbi.com
View Profile
Hi
The help does not tell me what the serial data is, just how to control the script.
The debug flag just calls up the help again
Code:
toledo version 0.0.4.3
 Always use flags --message and --output last
-h (--help)       This screen
-v (--version)    Show toledo version
-p (--port=)      Set the port for use (default /dev/tty.usbserial)
-d (--debug)      Enable debug mode (verbose, call this flag first)
-s (--sid=)       Which Sign ID is in use (default 00)
   --intro=       Set the intro effect (1-16)
   --exit=        Set the exit effect (1-11)
   --bell=        Add a noise to your sign (0-4)
   --speed=       Set the movement speed (1-4)
-f (--font=)      Set the font used (1-5)
-c (--color=)     Set color on supported boards (red, green, orange,
                    ired, igreen, iorange, rog, gor, rainbow
    --page=       Which page to progam (A-Z)
    --runpage=    Run which programmed page (A-Z) (non-functional)
    --link=       Run which pages in which order (A-Z)
-l (--line=)      Specify line to program, on supported boards (default 1)
    --raw=        Send protocol specific commands
                    Include the FULL string to send, everything between
                    <IDn> and XOR checksum
-m (--message=)   Set the desired message (call this flag before output)
-o (--output)     Output to sign (call this flag last)
example: ./toledo.py --link="ABACAB" --output
example: ./toledo.py -p "/dev/tty.usbserial" -m "Holy Toledo" -o
example: ./toledo.py --intro="1" --exit="5" --speed="2" --inverse --page="B"
          --line="2" --message="Holy Toledo" --output
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
tried the debug flag this way?
python toledo.py -p "/dev/tty.usbserial" --link="A" --debug --output
Logged
Rob Tillaart
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
The help text says --debug (or -d) has to go first.  Try:
python toledo.py --debug -p "/dev/tty.usbserial" --link="A"  --output
Logged
berlin
Offline Offline
Full Member
fubbi.com
View Profile
The manufacturer in china sent me the specs! Its all in there but I still dont get it :-)
I need to create one serial command to change "pages" from A to Z
that last debug suggestion worked
gave me:
<ID00><TA>00010100009912302359A5B<E>
 --link="B"
<ID00><TA>00010100009912302359B58<E>
 --link="C"
<ID00><TA>00010100009912302359C59<E>
Logged
Pages: [1]   Go Up
Print
Jump to:
